When i press the power button it lights up green then after a min in the front a red and a green light come on then everything turns off
SOURCE: Ricoh Aficio AP2000 Laser paper jam
Found solution myself.. The paper sensor arm with flag and sensor was missing from the exit side located on the fuser assembly.. Customer apparently broke off prior to calling for us to repair. Solution-replaced fuser assembly clean and tested works great
SOURCE: I HAVE A RICOH 1515MF ANS THE PRINTER LIGHT TURN
Press the printer button, it will tell you on the screen what the problem is. Generally it is because your computer is telling the printer that it wants to print on a size paper that you don't have loaded in the machine.
SOURCE: Ricoh Gx7000 inkjet A3 Printer - what does 'error
Error 990 indicates a dirty sensor, so either a maintenance unit is dirty or you have a clogged print head. You can read more about this error on Richo website where you can see in the images what you need to clean.
SOURCE: Hi, I have a Ricoh
Browse the below link & go to troubshooting section.
http://support.ricoh.com/bb_v1oi/pub_e/oi/0001030/0001030158/VG1487201/G1487201.pdf
I hope you will find your solution.
Thanks
