Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
Posted on Jan 07, 2009
Washer will not spin, will not spin in any spin cycle
Frigidaire front loading washing machine will wash. but when it goes into a spin cycle you hear it draining but not spinning.It gos back & forth but no spin not even in final spin. clothes are soaking wet when wash cycle is done.
  • rexer510 Feb 21, 2009
    How do you clean the water pump?
Anonymous
Level 1:
  • Contributor 20 Answers
  • Posted on Feb 10, 2009
Anonymous
Contributor
Level 1:
Answers
20
Questions
0
Helped
33341
Points
38
Your water pump is clogged
Frigidaire model # GLMV167OAS Makes a loud buzzing noise during the spin cycle. Completes the cycle but clothes are still sopping wet. What to do???????
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Washer will not spin goes through all cycles but clothes are left soaked
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
My Figadare front load washer will drain but will not go into spin cycle
heatman101
Washer will not spin. it will agitate during the wash cycle but not spin
heatman101
Washer will not complete spin cycle clothes are still wet
My front load washer just stopped spinning. Every other cycle works!
heatman101
2answers
Frigidaire Front Load Washer - does not rinse and spin
sounds like the timer went out replace it should solve problem
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
