My machine washes perfectly but does not lather , i have tried both powder and capsules
SOURCE: error codes for indesit front load washing machines
The F002 error codes relates to a motor problem. Do you know if the motor spins ?
SOURCE: Indesit front loading washing machine error code
i am a recently retired engineer of 20 years, but this sounds like (based on the info given) a heater element fault, after the machine fills up and agitates a few times the heater should start, check the heater for open circuit, replace if needed, of course it just could be a wire off? if i have helped rate me please
SOURCE: indesit washer dryer stops halfway through a wash....
depends on what lights are flashing this is your fault code
SOURCE: WIDL102 indesit washer dryer not working properly
check heater element/ should read about 32ohmns on multimeter if not reading replace,if ok replace stat
