Question about MediaFORM CD 3702 Burner
Reinstall Os Is it possible to reinstall os on mediaform 3702. I don't know what OS it has installed before. Harddisc has crached and will replace it with a new. Can this be done.
  • 661 Answers
I'm not entirely familliar with this system and also it appears to be discontinued from the manufacturer, http://www.mfdigital.com/ it may be possible to "clone" a disk from a working one using Norton ghost or something similar. (but that means finding someone willing to let you dissasemble their working one), with norton ghost you should be able to copy entire disk from the working disk to a new disk. the manufacturer does have a firmware update disk for this but that most likely only updates the system once it is working. Gareth
Posted on Jul 26, 2007
  • georgeserr Nov 21, 2010
    I have a system that isn't loading cds correctly however the hard drive is working. I wouldn't mind uploading an image of it if your interested still.
Anonymous
SOURCE:
Mediaform AP 1001: Harddisc crashed. Does anyone have an idea how to prepare/record new harddisc; which software is needed?
Check out podnuts computer repair forum @ http://www.podnutz.com/forums/ for good answer and relevant info
Feb 10, 2015 | Computers & Internet
DISC CRACH
If your hard drive is "crashing" and you can still access it, copy any important files off of it thay you want, like docs, pictures, music, etc... From there, you need to replace the hard drive, they are not extermely expensive and easy to install. If this is your main drive with your OS on it, you will then have to reinstall windows or whatever OS you have, then copy your files onto the new hard drive. If you cannot boot up because it is your main drive and has already crashed, your best bet is to get a new one and reinstall your OS, then get an external hard drive reader and try to access it and get your files that you want. If it is crashed, not accesible, the only way is to take it to an expert, which is very expensive. Unless these are "must have, can't live without" files, you probably will just have to take your lumps on losing that data. Either way, when your HDD starts to go, it is usually only a matter of time before it totally crashes so a "repair" or quarentining any bad sectors is only a band aid and will eventually, sooner than later, die on you all the way.
Sep 27, 2012 | Computers & Internet
How do i format it to how it was when i got it
If you still have the disk for your OS then the process is fairly simple. Insert the disc and reboot the computer. While the computer is booting hold down ESC or possibly F2, F8, or F12. A boot menu should open up before your operating system begins to load and you should pick to boot from CD Drive. When the setup loads, go through the menus until you get to the section of where to install the OS. Delete all the partitions on your computer and then reinstall the OS on the new one. This will delete everything on your laptop and just have a clean copy of your OS.
If you don't have the original CD you can download and burn this onto a CD and boot it from CD. This will securely wipe your hard drive.
Apr 25, 2011 | Acer Aspire One PC Notebook
I have avg security...and its saying that im not protected...some of it wont work...and wont let me fix it
ok so your protection migh tbe infected, sometimes viruses attack your virus protection then utilize it to destroy your OS [operating system]. One issue is that the only to fix it completely is to re-install your OS.
BUT many people dont know how or are affraid of installing it, many people have information on a computer and they want to keep it. My method invovles storing that data in a safe place IE a flash drive, DVDS or CDs, or in some cases the second harddrive on your computer,
also you must own a OS disc with a serial number from your computer.
BUT i have a disc with a modified version of Windows xp professinal so i can reinstall my OS anytime i feel like it. So if i were you i would start backing up your data as your OS may be comprimised. then after saving your Important info and other data you may reinstall or use a recovery mode in your computers,
i know this isnt much help since you prolly dont want to reinstall your OS with all your data, but thats why u should back up your data and then possibly find the solution without the worry of losing it. many times the only way to solve these issues to have a clean install of your OS, but the means to do it are quite complicated if you havent done it before. just PM me if u want the Modified version of windows xp
Jan 03, 2011 | Computers & Internet
I don't know how to format my pc. and reinstall xp
before u decided to format and reinstall ur os
check whether the cd and serial is available
1. to format just right click the drive (c:\) where ur os is present
2.click the format option in right click popup box
ensure ur format action
now ur os get removed
3.insert ur os disk in cd drive
and follow the instruction specified by the os installation wizard
May 18, 2010 | Computers & Internet
Laptop OS re-installation
Toshi, good to know you from nagaland. for your problem, download your drivers from
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=3466274
and burn a cd for future.
Sep 03, 2009 | Computers & Internet
Hi Please help - I require a BIOS upgrade
Try first to If bluescreen comes and reboot after to diasble reboot an writing here what on the blue screen they writing.
Other solution maybe possible :
1. Run chkdsk if possible so windows can find erors on the Harddisk.
2. Disconnect all usb except keyboard and mouse
3. uninstall new software installed on the computer (during the last 7 days)
5. maybe it can bee some hardware on the computer that is defect, ex your harddisc/ Dvd drive
Please let mee know if this solve the problem.
Aug 22, 2009 | Computers & Internet
Bluetooth device not working after windows got reinstalled
What is the old OS and the new OS of your computer? If you upgraded your system, there's a possibility that your Blyetooth device was not supported by your new OS.
Or, you might need to download a new driver that would support your new OS.
Byt if you are running the same OS, try to download the driver from the Internet and reinstall the Bluetooth driver.
Have a great day!
May 18, 2009 | Acer Computers & Internet
How many times OS has been installed on system.
sorry. but no way to know because each time an OS is install. The drive gets formatted. All the previous information usually is gone. Even by chance they did a quick format and some information in retained on the drive. you will need someone professional to retrieve it and still maybe can only retrieve 10% of the previous information.
May 16, 2009 | Microsoft Computers & Internet
Harddisc crashed
Take a look here http://www.fixya.com/support/p138332-mediaform_cd_3702_burner
May 29, 2007 | MediaFORM CD 3702 Burner
MediaFORM CD 3702 Burner Logo
116 people viewed this question
Top MediaFORM Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a MediaFORM Computer and Internet Expert? Answer questions, earn points and help others
