Bought the phone used. Tried to activate (4 times) on solavei, but it isn't working. Reset the phone to factory. Signed up on zunes. Changed access point name to solavei. Still not activating. Is the phone locked, even though it is a T-Mobile phone? Maybe the previous owner did not pay for the contract?
SOURCE: cant reset with security codes from factory
Your only choice is reflashing the firmware on your device, which will wipe out everything incl. security code. After reflashing your code will be 12345. You can use program called Nokia Software Updater.
Rate me if helped,thanx.
SOURCE: callers' name doesn't show even though i have them in my contacts
Solution 1
Some caller's names does not appear even though they are on your contact list because you have then copied twice on your phone. What you'll need do it to delete one contact each for the caller id's that don't show when they call in. Once you get this done, your phone phone would begin to show contacts on your phone.
If you want to know if this true, then get someone around you and save his/her name twice then ask him/her to call you. You'll notice that the caller id would not appear, but once you get one of the contacts deleted and ask him/her to call you back, you'll discover that the caller's id would begin to show.
Solution 2
For your access point, just define it the next time you switch on your phone and save it. Then it would not have to change the next time you turn your phone on/off.
Solution 3
To get rid of the welcome go to Menu > Tools > Settings > General > Personalization >
You can set it from here.
Hope this helped.
SOURCE: i dont know my lock
If you forgot the password or don't know the security code, You have to master reset the phone. Contact your service provider to get a master reset code at free of cost....You can also visit http://www.unlock-zone.com/ and can see different options there to get unlock code for a price. Choose any price appropriate for you.................
SOURCE: My E72 keeps on saying
Maybe your Packet data conn. was set to "When available"
Go to Tools->Packet Data and select the Packet data conn. and change it to "When needed"
Hope this helps.
SOURCE: Hi,Iam with aircel chennai.Iam using
Get into your N73's Internet settings and use these information:
Aircel GPRS settings
or
call the toll free number of Aircel and ask them to send you the internet settings to your phone.
