all of a sudden, can't get my pictures....message says Media Card Not Properly Inserted....I've never touched the media cardall of a sudden, can't get my pictures....message says Media Card Not Properly Inserted....I've never touched the media card
You can't post conmments that contain an email address.
You need to format the card. Go to options, scroll down to "media card". Click on this, when it opens, make sure media card support is "on", .......make sure Mass storage support is "on" Then click on "Menu" which brings up the option to "Format card" Then cliuck on this option and it should be OK,
first of all try inserting the memory card into other phone if it works then format it and re-insert it again.if still it does'nt work then check out your memory card jack present in blackberry.
My card's properties shows "Generic Flat" probably a linux file system. A windows OS will show the card when inserted in the device but there is no option to format. When inserted in a card reader windows will not recognize it. Resign yourself to using the card in the phone or find a linux computer. Try booting your windows machine from DVD-Rom with Knoppix, a live linux file system. If the card is recognized format to a FAT 32 or NTFS file system..
The best thing you can try to do is connect the media card to your computer. When you see it show up in "my computer" or "computer" right click on it, and select "format". Make sure the formatting is in either FAT or FAT32. Once that is done, put it back in the phone and try again. If you cannot plug the card into the computer, then use the supplied USB cable for the phone, and plug that in to the computer. On your screen it will ask if you want to sync, enable mass storage or charge only, make sure you select enable mass storage. If you do this your card should be readable on the computer and then you can format it using the same method I described. Just note that if your blackberry gets plugged in, it will show up with 2 "storage cards". One of them is the memory that is on the phone and the other is the actual media card. Make sure it is the media card that you have selected to format.
From the Home screen of the BlackBerry smartphone, click Options > Media Card or Options > Advanced Options > Media Card. Display the menu and click Format Card.
some times Format Card option does not appear on the menu, skip the step and perform the procedure that follows.
A warning message will appear asking if you are certain you would like to format the card. Click Yes to continue. If the Format Card option does not appear on the menu, complete the following steps:
On the Media Card screen, set the Mass Storage Mode Support field to Off.
Display the menu and click Save. The Media Card screen closes automatically.
Click Media Card to reopen the Media Card screen. To format the media card, display the menu and click Format Card.
Complete the following steps:
1) Use a search engine or a dedicated download site to find and download a third-party conversion tool. The tool must have the ability to convert the format of the audio or video file to a file format that the Media application can read.
2) Install the third-party conversion tool and follow the program instructions to convert the audio or video file to a format that the Media application supports. Refer to the following tables for optimal settings in the Media application. Optimal settings for the Media application on the BlackBerry 9000 series smartphones:- For video setting's a) Video format: MPEG-4. b) Video file extension: .avi
c) Resolution (4:3): 240x180
d) Resolution (16:9): 320x180
e) Video bitrate: 400 Kbps
f) Frames per second: 24
For Audio settings:-
a) Audio format: MP3
b) Audio bitrate: 128 Kbps
c) Sample rate: 44 kHz
d) Channels: 2 (Stereo)
Transfer the audio or video file from the computer to the BlackBerry smartphone using one of the following methods:-
1) Using BlackBerry Desktop Manager. Note: BlackBerry Desktop Manager 4.2 must be installed on the computer.
In BlackBerry Desktop Manager, open BlackBerry Media Manager.
Use the Media Manager tool to transfer the audio or video file to the BlackBerry smartphone using a USB connection.
Copy the files to the appropriate folder (either \blackberry\Music or \blackberry\Video) on the media card, or directly to the internal BlackBerry smartphone memory.
Note: Files larger than 3 MB cannot be transferred to internal BlackBerry smartphone memory. 2) Using the BlackBerry smartphone as a USB mass storage device:-
On the BlackBerry smartphone, go to Options > Advanced Options > Media Card.
Make sure that Mass Storage Mode Support is set to Enabled.
Connect the BlackBerry smartphone to the computer and follow the prompts on the BlackBerry smartphone.
Open the My Computer folder on the computer. The media card should appear there as a Removable Disk.
Copy the files to the appropriate folder (either \blackberry\Music or \blackberry\Video) on the media card.
Using a media card reader
Make sure that the media card reader is connected to the computer.
Insert a media card into the media card reader.
Insert the media card into the BlackBerry smartphone.
format the mem card through your computer instead maybe, it works best if u have a usb reader that the sd card slot in then jus plug it in. if it dont automatically show up on pc go to 'my computer' in the menu and it should b found there prob as removable drive, once in it right click mouse and should b an option to format sd card, hope this helps.
I have the same problem
