Boston Acoustics TVEEM25 TVee Model 25 SoundBar Speaker System - Logo
Posted on Nov 17, 2012
My sound bar hooked up directly to my tv has no sound
I used both the RCA cables and the optical cord and hooked it directly to my tv.... No sound... I have a Sony Bravia tv ...do I need to Chang the settings to get the external sound bar to work? I did hook it up to the earphone jack via the aux port and it worked but I'd like it to work with the RCA and optical too...
  • william_s_jo
    william_s_jo Nov 18, 2012
    Solved.... Yes you do need to disable the internal tv speakers but I had done that... I had to go through the cable box instead of the tv.... Ithat was my solve.... If you don't want to do that you can go from the aux to the ux on the tv
I want to extend length of cord so sound bar is next to my husbands chair. Not sure what cords(s) needs to go into tv and what connection on the bar. this is to amplify the sound for him.
First check to see if the tv and sound bar have a optical connection. If so one optical cable the correct length will connect the sound bar. Otherwise you may nee the red and white RCA connector cable to extend from the tv to the sound bar.
Cannot be more specific without knowing type and model of sound bar and TV or AV system you are using.
I have a lg sound bar optical cable but no optical cable on Panasonic tv how do I connect sound bar
Are there any other connector inputs on your soundbar?
If not you may need to purchase a digital to analog converter. Fiio makes one as do many other companies. Easily found on Amazon for about $20.00.
You hook up your tv's RCA audio output to the RCA input on the converter and then the optical cable to the converter then to the soundbar. That's how I would solve this issue.
Can i connect an rca sound bar to insinia tv?
If the TV has an optical out and the sound bar has an optical in, then all you need to do is get an optical cable and take the rubber safety plugs out of the TV and sound bar and connect the cable. Then go into the audio setup of the TV and select optical so the TV will direct the audio from the speakers to the optical out of the TV.
Having problems connecting using RCA cables (TV to Sound Bar) - No sound on Sound Bar
I assume by using your phone (cable rca to mini jack) the sounbar functions normal. Next time give more info like tv and soundbar make and model no and what connections are available on both components and if its input or output connections.
On the tv make sure the rca cable (tv to soundbar) is plug into the stereo output of the tv and not in a av input. Some tv's have a mini jack out and not rca. Some have a earphone socket which could also be used.
Some tv's only have a digital or optical output port. Iin basic sound work and can be connected with the following combinations .
Minijack to minijack
Minijack to rca
rca to rca
digital to digital
optical to optical
Wanting to hook up a sound bar to TV model
The cheapest way of connecting your flat screen and soundbar is to use the TV's headphone jack. It's not the best quality, but a lead will cost a couple of Pounds/Dollars and it will do unless you want the sound really loud.
If you want the best quality then the answer is to use the TV's Optical output. This sends a signal in digital form as a series of light pulses. This isn't directly compatible with the stereo input of a sound bar. There's no kind of cable or plug adapter you can buy that converts this just through a piece of wire. So you would buy an Optical to Stereo phono/RCA converter that can translate light pulses into a stereo signal. Here's a link to one from Amazon. It is less than 10 Pounds Sterling
Cable Mountain Digital Optical ToSlink Amazon co uk Electronics
Why doesn't my lg soundbar play sound from the optical cord connected to the TV?
one issue could be power source to the sound bar, another could be that the optical cord is not hooked to the power output source, if you have cable or satelllite then that is your source, not tv
My TV has terrible sound at volumes where we can actually hear the TV. It gets warbled like the speakers are bad.
The TIVO system is not a problem. I have it and it works fine. Make sure all the cords are plugged and screwed in tight.
Sound bar setup
see this . God bless you
831d4bf7-b33d-475c-b709-bca857d43eb3.jpg2e546a78-185c-49d6-8958-689f2c5119fe.jpeg2c103a19-a29a-4301-9c23-1f3896cea0f0.jpegc9c5b78a-6c99-43ff-be85-91afda28411e.gif
LG blue ray won't play sound from RCA sound bar. HDMI cable is hooked into HDMi slot on TV
the details you provided were very vague, however from my experience when a device is connected to another device via and audio capable hdmi cable, that device renders it audio output to the device its connected to and normally turn off all other audio outputs beside optical- I would assume there is an option in the blue ray player to turn off hdmi audio, which will in turn activate other audio outputs- you may also look for audio out port on your tv, it is ideal to connect the sound bar directly to the tv set audio out ports. To sum this up,
if you plan to use your player via hdmi cable you need to turn off hdmi audio output on the blue ray player and the plug an audio cable from your blue-ray player to your sound bar
you may also as i said connect your sound bar directly to your tv, the issue is most tv sets now a days do not have an audio out port, if you do then everything you play thru your tv will have audio via sound bar
there are several way to go here but unless your sound bar has hdmi av switching capabilities (im sure not) this is one of the most simple--Good Luck.
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
john h
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
