I have canon 580exii speedlight and 2 270exii, I want to use the 270 as slaves, I don't want the master to flash, followed the intructions in booklet, told me to turn off the master, when I do that, the slaves will not fire.
You didn't say what camera model you are using.
If you have 7D/60D/T4i you can have a total of 3 wireless ir flashes.
580EX II must be set at Master, say Group A & Channel 1
Two 270EX II must be set at Slave, say Group A & Channel 1
or
One 270EX II set at Group A & Channel 1
Second 270EX II set Group A & Channel 2
Then go into camera menu & turn off Master flash & turn settings for those two flashes.
Send me a email, then I can help you much better.
[email protected]
SOURCE: canon 430EX flash will not flash in slave mode.
This site worked foe me http://flashzebra.com/wizardcables/index.shtml
Good luck
SOURCE: af assist on canon flash 580exii not working
check Custom Functions of Camera and Flash it can be turned off in both locations
SOURCE: Iam having a problem getting the two flash units
Make sure the slave is far enough in fornt of the master flash to see it. If the two flashes are next to each other then the slave is not seeing the master signals.
SOURCE: reverting to ttl - master flash not firing
Hi Kate,
What camera that you are having problem with those flashes?
Will switching the two have the same problems.
Make sure it is fully pushed forward into hotshoe & locked:-)
Try shooting second current, this will save you the repair costs.
Your exposure compensation was set to zero, but was your flash compensation set at zero?
[email protected]
