I have an Apex HT-150 surround sound system and i was wondering how i would connect it to my TV and watch regular television with surround sound. I was also wondering if its possible to play my Ps3 with surround sound. The ps3 is connected with an HDMI cable to my TV. Im confused on how they all would be hooked up and necessary cords that are needed.. thanks for any help and advice..
SOURCE: help
This is possible a number of ways. Depending on the type of TV you have, it may have audio out on the back of the TV. This will be two jacks that are RED and WHITE, and it should be labeled "TV OUT" or "OUT". Use an RCA audio cable and connect these two jacks to the TV jacks of the same colors on your surround sound unit. If your TV does NOT have audio out jacks, you can still accomplish this by use of a VCR. Just run your main TV input [coaxial cable from antenna or cable/dish] into the VCR, and then out to your TV as normal. Leave your TV on channel 3 [or 4, or whichever channel the VCR uses]. If you're using a regular antenna, you can switch channels on the VCR. If you're using cable, you should be able to just change channels on the cable box. This will give you surround sound from an older TV without audio outs. But most larger and newer TVs have an audio out jack on the back. Hope this helps!
SOURCE: Samsung HT-TQ85 HDMI Input not working
I rember reading an article stating that the HDMI does not suppory audio
SOURCE: I have an Apex LD4088.
Try unplugging the tv power cord for 30 seconds. Then replug, it worked for me.
SOURCE: apex ht 150 region unlock codes - australia
Hi, kindly get the code here :
www.dvdexploder.com/
www.download-info.com/dvd/index_new.htm
www.220-electronics.com/dvd/ht.htm
www.videohelp.com/dvdhacks
Regards, Jay__JnyBg
SOURCE: need to unlock region code
www.regionfreedvd.net/ www.dvdripper.org/dvd-region-codes-vs-ntscpal/ www.regionfreedvd.net/players.html
www.dvdreviewer.co.uk/Forums/...region_code/page1
Best Regards, Jay__4r5e
I HAVE A KENWOOD HOME THEATRE SYSTEM IM TRYING TO CONNECT ED TO MY SYLVANIA LCD TV HOW CAN I DO IT.
how many aux. inputs for the red and white audio rca jacks on the system ?
does your tv have audio outputs? or are you using the converter box required for the digital transition?
also i don't belive that your system has a digital input audio connection ( optical or coax digital audio decoding stream ) so you would only be able to use the pro logic setting for any audio that you input to the ht 150 system
Does your tv have an optical or coaxial digital out. Does the home theatre system have a optical, coaxial or hdmi in?
