The cold water solenoid gets power intermittantly a few times then goes into alarm
SOURCE: Will not advance from fill cycle
Check your drain hose to make sure you have not sealed the top of the standpipe (drain line), or shoved your drain hose too far down in the pipe. If you do not allow for an air gap, your washer will fill and begin to siphon through the drain line. It is common for folks to seal the standpipe or shove the drain hose down in the line too far in the belief that it will prevent overflows, or get rid of that nasty drain smell. This can be bad because it does not allow for the proper air gap to keep the water from being siphoned right out of the machine. You may have a tight fitting that doesn't siphon every time which may explain why the problem doesn't occur all the time. Double check to make sure. Hope this helps.
SOURCE: Fisher and Paykel 6.5 smart drive washer
My F & Paykel washer did this. There was a baby sock under the wash basin. I called for repairman and he found the problem.
SOURCE: Slow fill on cold water/Fisher&Paykel GWL11
Assuming you have already done what you said you have done, now it is time to do some real troubleshooting.(Dont worry, if you have gone this far you'll be able to do what I'm going to tell you)
First take the lid off. To do this, open it, and lift up on one side, it should come right off. Now take the control panel cover off. There are two screws on the back side of the washer holding it on. You'll need to wiggle it a bit to get it off. Once the cover is off you should find a plastic bag with a "service" sheet in it. The service sheet explain how to put the machine into the "Test Mode". This is very easy to do and will allow you to check out all functions. One of the test, allows you to check the cold water inlet valve. Assuming your water pressure is good and you have indeed cleaned the screen filter going into the machine you will most likely find that the cold water valve is not opening all the way and will need to be replaced. If your handy with a phillips screwdriver you only have two more screws to take out and the valve assembly will come right out.
Don't think you can swap out the hot water valve with the cold water valve. Fisher Paykel, clever as they are made sure you can't do that. One is a proportional valve and the other is a digital valve. They both look identical but they are not!
If your going to do the repair yourself (you've come this far, why not see it through to conclusion), be sure when you call Fisher/Paykel to order the cold water inlet valve that you give them the serial number of your machine to be sure you get the correct part.
Good Luck!
SOURCE: Fisher & Paykel Washine Machine is filling up hot and not cold?
As nice as these machines are, I've read bad things about Fisher & Paykel reliability. It sounds to me like you have a bad solenoid.
FYI, you should leave the water lines on (both hot and cold) all the time, no need to shut them off unless you're unhooking the machine to move it or work on it. The machine should control the temperature itself.
SOURCE: fisher & paykel fill up with water then
Yep it sounds like another electronics panel has failed.
We never had this much trouble in the old days with the old electric timer machines.
