Samsung LE46M51B 46 in. LCD Television Logo
S Jackson Posted on Nov 18, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Samsung TV Screen faulty
My 52" Samsung LCD/HD TV (Model Number LE46A557P2FXXU - Version AA01) is having major screen problems. The entire left hand side of the screen is under a dark shadow and very blurrey with horizontal lines across the top however the right hand side is fine. This has now been ongoing for a few weeks and initially it appeared that once the TV had warmed up it gradually disappeared however this is no longer the case. The TV is only 4 years old. Any suggestions?
Russ Hill
Level 3:
  • Samsung Master 4,057 Answers
  • Posted on Feb 09, 2014
 Russ Hill
Samsung Master
Level 3:
Answers
4057
Questions
10
Helped
1175554
Points
12696
T con board failed if its half and half. can also be a lose cable on the screen to the tcon board from the lcd screen side. Tcon is in the middle off the screen on the back.
5 Related Answers
Anonymous
  • 10 Answers
  • Posted on May 23, 2009
SOURCE: LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
This should be repairable. It may be the LVDS Cable or the Main board problem. The only other problem is the T-Con Board.
Anonymous
  • 38 Answers
  • Posted on Apr 20, 2008
SOURCE: SAMSUNG LCD TV horizontal lines
causing of horizontal lines is leaky or defective capacitors. check big value capacitors around the board at Horizontal area. check the filter capacitor as well. good luck
Anonymous
  • 98 Answers
  • Posted on Feb 06, 2009
SOURCE: Vertical lines in LCD tv screen
Need to check the two things.
1st -- need to exchange T-con Board.
2nd -- need to exchange the cables between T-con & LCD panel or
between T-con & Main(LVDS cable)
Anonymous
  • 5 Answers
  • Posted on Dec 22, 2009
SOURCE: Samsung Plasma TV has horizontal lines of colored dots
I have the same problem, currently searching for a solution. Have you resolved your problem yet? Looking to repair myself, any tips or ideas that you have/expirenced would be greatly appreciated. Thanks, Todd
Anonymous
  • 26 Answers
  • Posted on Feb 11, 2010
SOURCE: Lines across screen breaking picture into 4 sections
Based on reported problems with Samsung LCD tvs, It is probably one of three problems:
Separation of layers of the LCD panel;
A defective LVDS cable connection;
A defective T-Con circuit board.
If light hand pressure on the affected area on the LCD panel changes the problem, its the defective panel. If not, manipulating the LVDS cable will reveal the cable defect. If not, coolant spray applied to the T-Con circuit board should reveal if it is defective by temporarily alleviating the problem. Dont remove the back cover if you dont know how to protect yourself from electrical shock hazards. There can be more than 1000 volts in the backlight inverter area.
Jerry S
1helpful
Samsung LN37A550P3FXZA; bright screen, images are yellowish and very faint.
If you wish to get some details; check the site linked here. Pull up older posts.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Screen is blackened on top of screen
assuming your TV is an LCD, there is an issue with the CCFL lighting tube/s and one or more needs replacing/repairing.
if your TV is LCDLED then there is an issue with your LED lightstrip - probably faulty circuitry and would need replacing.
unless you are confident with stripping your TV (which i doubt) then you will need to pay someone, and it will probably cost LESS to just buy a new TV -- they are getting very cheap.
Screen is black after the initial white screen that displays "Philips" Sound there but black screen with no picture Menu does not show either Nothing but black
I believe a firmware update can fix this issue. However to be sure I would need your entire model number, including the numbers after the slash. You can put that entire model number into Philips support website, http://www.usa.philips.com/#/headernav/consumer/
Once you get to your TV's support page, you can look on the right hand side and find the firmware information. First I suggest you read the Read Me file to familiarize yourself with the update process and what issues it fixes. Then you can download the firmware to your computer so you can upload it to a USB drive to perform the update.
Hope that helps!
1helpful
No picture only sound ( plasma 52 inch )
Hello Fixya customer,
Thank you for your question.
There are several possibilities here including the signal source, a fault in the video processing, or panel display drivers.
This can be narrowed down further for your model. Please supply the full model number of your TV.
Thank you for using Fixya, and I look forward to your response.
Jvc 52" hd tv screen yellow
Have crack screen sign?Not fixable only require LCD changing,not buy able LCD screen only can buy it new from the tv compannies,but only sell as new tv only.
2helpful
Hdtv picture freeze
I also have a Brand new Sony Bravia 52" LCD with Comcast Cable (motorola box).When switching between HD Channels sometimes the left side of the screen shows a smushed version of the new channel, and the right side is a frozen picture of the previous channel. I correct this by switching to a non HD channel and back. Cable or TV problem I wonder?
13helpful
3answers
Samsung LCD tv wont turn on
what the full model number of your tv?
the clicking sound is the result of a faulty power supply, some capacitors(blown heads) on the power supply for the output voltage rail of the mains board need to be replaced.
pls rate me!
Vertical Lines and Ghost image then powers off
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts..
SAMSUNG 46 LCD 1080p series 5 - LE46A557P2FXXU - black screen
the x or y board may be bad in the set. i would say it is the main board.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
