Our TV is stuck in zoom mode. Top and bottom words cut off. Don't have original remote. Using disk network remote-they say it's a function of the TV. No zoom feature to be found on TV menu. Help?
Sorry u can't fix this zoomming mode problems without the tv original remote.This tv zoomming mode function it is have it only on the tv original remote function only no where else.Try website like Remotes.com to buy the tv original remote to use.
Hello! This can be frustrating to watch!! To change the format on your DISH remote, all that you need to do is press the * button below the number 7 on the keypad. This will change the format for the TV so that you find the one that suits you best. The best that I have found is Zoom. I hope this help!
Using the menu or settings button on your remote, access the TV's menu and find the area for picture settings and zoom. You're likely set to a zoom mode, so cycle through the options until you find the zoom setting that sizes to your TV best. (On most widescreens, the best picture is often on the setting 'panarama.'
Press the "Aspect" button on the remote until the picture looks appropriate. You are probably trying to display a 4:3 ratio channel on your 16:9 ratio TV. You are probably viewing it in "zoom" mode, which does not stretch the 4:3 ratio video, but enlarges it until it fits the width of the screen, which zooms part of the video off the top and bottom of the screen.
Does the tv menu or tv remote have a zoom option? It may also be labeled as "aspect ratio" or the like. I suggest trying to find this and pressing the buttons a couple of times until you get a satisfactory image.
Check what format you are in. 4:3 is like a regular tv. Sides will be cut off in this format on a widescreen tv. 16:9 zoomed will cut of top & bottom slightly. You want just regular 16:9. No zoom.
You would look for a format button on your remote.
Dish Network: bottom left the asterisk "*" button
DirecTV: top left, second from the top labelled "format"
Cable remote: look for format, zoom, or aspect ratio
Pressing this button should scroll you through the options.
If you are using Dish Network, while in SAT mode, hit the star key on the remote (also labled FORMAT). It will start scrolling through certain modes: zoom, partial zoom, normal, stretch... etc)
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made.
For example:
A Motorola Cable box needs to be set up to go to a wide screen or zoom when an analog signal is detected.
Some Dish Network boxes have Size buttons on their remotes and also in their main menu.
It's difficult to determine the repair without knowing the types of the peripherals.
Hope this helps.
