From Brother website/help
Click the Add Port... button.
Select the Standard TCP/IP Port option and click
New Port. The
Welcome to the Add Standard TCP/IP
Printer Wizard appears.
Click Next.
In the Printer Name or IP address area enter the node name
of the
Brother device as it is printed on the network configuration page.
An
example node name could be: "BRN_34FDAA".
As you enter the node name, the Port Name box will be
automatically updated.
Click the Next button.
Click the Finish button.
Click the Close button on the original Printer Ports
screen.
Click the Close button to return to the original properties
screen.
Click the Apply button and then the OK
button.
Now try to print a test page.
This worked great for me!
1. Make sure that the power is turned on.
2. Open the Front Cover.
The FINE Cartridge Holder moves to the replacement position.
3. Remove the empty FINE Cartridge.
(1) Pinch the tabs and open the Ink Cartridge Locking Cover.
(2) Remove the FINE Cartridge.
4. Prepare the new FINE Cartridge.
(1) Take a new FINE Cartridge out of its package and remove the orange protective tape (C) gently.
5. Install the FINE Cartridge.
(1) Put a new FINE Cartridge in the FINE Cartridge Holder.
The Color FINE Cartridge should be installed into the left slot and the Black FINE Cartridge should be installed into the right slot.
(2) Close the Ink Cartridge Locking Cover to lock the FINE Cartridge into place.
Push down the Ink Cartridge Locking Cover until it clicks.
(3) Confirm that the Ink Cartridge Locking Cover is closed correctly.
6. Close the Front Cover.
1. Make sure that the power is turned on, and open the Paper Output Tray.
2. Lift the Scanning Unit (Cover), then hold it open with the Scanning Unit Support on the right side.
3. FINE Cartridge.
(1) Take a new FINE Cartridge out of its package and remove the orange protective tape gently.
The Color FINE Cartridge should be installed into the left slot and the Black FINE Cartridge should be into the right slot.
(E) Closed correctly
(F) Not closed correctly (the cover is tilted)
6. Lift the Scanning Unit (Cover) slightly to set the Scanning Unit Support back to its original position, and gently close the Scanning Unit (Cover).
