Okay, when switched to TV std cable all I get is a blue screen w/ sound. If I switch it to TV w/ antenna the screen rolls like a horizontal problem, but either case the HDTV plays just fine and crystal clear. Any Ideals? The TV used to play fine, but as soon as I bought a new TV for the family room it started this , honestly.
SOURCE: Westinghouse LTV-32w4 HDC widescreen DVD Combo
Hi Mouse999. From reading a bit, it seems that there's no region free hacks for the built in dvd player in that specific model. A solution for you, would be to purchase a standalone dvd player, one that is region free or one that has a region free hack available, and to connect it to that tv. If you're in europe and your tv is pal, you also need to have a dvd player that will read both Pal and NTSC video dvd's ! If that doesn't help, please be more specific, i'll be glad to help. Thanks, cheebster.
SOURCE: Westinghouse ltv 32w4 hdc 32.02 in. hdtv lcd tv / dvd combo
My 42" Westinghouse HDMI inputs just stopped working. I thought it was the TW Explorer 4250HDC issue so I got a new one from TW. Still said no signal from HDMI. So, I shut the TV down and pulled the power cord out of the back. I waited a few seconds and reconnected the pwr cord. The TV "re-booted" so to say and now the HDMI inputs work. I think TVTEK has the right idea that it is firmware/software related. In the mean time, you might want to give that a try.
SOURCE: how to remove dvd drive for Westinghouse LTV-32w4
http://www.retrevo.com/support/Westinghouse-LTV-32w4-HDC-TVs-manual/id/278ci973/t/2/
First you would have to get a service manual, this shows you all you need to know about the unit. Without it, it is very difficult to even remove the case. but once inside, it is basically a simple task, to find the drive, remove the fastenings, and the Cable, obtain an EXACT replacement HDD, and reverse the procedure, it may pay to format the HDD first, FAT32, I believe, although your manual will be more specific.
SOURCE: My Westinghouse LTV-32w4 HDC has went green.
The Tuner signal board is dead.The Tuner signal board,that the board,where the incomming broadcasting signal plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
all channels have been scanned but only HDTV channels will show a picture, any ideals?
