I updated my lcd samsung firmware and afterward the color of the tv went crazy. how do i put back the original firmware or get the original firmware back on to correct the problem.
You need to go into the service menu and adjjust the option bytes. When you upgraged you changed them. The other solution would be to replace the main pcb
you can really mess things up so be careful.. with the set in standby (off) press mute 182 power. look around the menu for option bytes write down the numbers. keep me posted on this. there are other tricks in the menu to try.
it is mute, 182 power with the tv off using the samsumg remote.
look around the menu for the word "bytes:
write down the option number then select another then check the picture after you make the change
send me your complete model number, serial number and version number
ok, I will research this and get back to you.
where do you go to the service menu and how do you adjust the option bytes.
nothing happen, it just turn on like u watch tv. no option menu at all.
i did n it did get anthing but turn the tv on
ok , the menu came on, what do i do next, i needed to turn off the stb box to see it.
ok, than what to do
what to do next, tech 1819, i thank you for all of your help!!, please help me.
i tried, but didn't work
MODEL # LNT4661FX/XAA
SERIAL # AHBB3CPPC05484Z
VERSION # SX07
THANKS AGAIN TECH 1819 FOR ALL YOUR HELP!
thanks , my email is [email protected], if you needed to find me .
