All routers work the same basic way. you connect a pc using a LAN cable to the router. You open a web browser and type in the IP address of the router. this is usually 192.1681.1 or 192.168.0.1 , but occasionally can be something else. its usually printed on a label stuck to the router. Once you get that right a login screen will appear and you must use the login user/password (admin,admin or admin,password is often used) which should also be printed on the router underside. Then the router will present a menu to you, and somewhere on there will be the wifi setup. they are all slightly different so refer to your manual or just use your common sense.
SOURCE: where can i log on to the router or change its password?
To access the router's configuration you need to type its IP address into a web browser. The default IP is 192.168.1.1 but if that doesn't work you can find it out with the following steps:
I hope this helps!
SOURCE: zhone linksys router
I had same problem but I think it's more of a simple solution. Linksys default IP it uses is 192.168.1.1, and guess what...so is the zhone router. I changed my linksys router to 192.168.10.1 and i am able to connect to the internet. Only problem I have left is some things are not working such as MSN messenger and https pages. I am wondering why...
SOURCE: zhone 6218
Zhone (6218-12-200) I have wifi encrypted to manage 4 passwords. I am having a problem entering 3 additional at 64-bit - keeping in mind each person would be assigned to individual access codes
SOURCE: Need login and password for a Zhone router/modem
If you got your Zhone modem from consolidated communications then the login is admin pass is cciadmin
