Hello, are you looking for a diesel generator? Or you just want to know about generator related information?
When you choose a electrical diesel generator, you need to consider lots of factors. Read this article to get some suggestions. Important Factors Should be Considered When Purchasing Generator Set
there are natural or lpg operated engines in gen sets being sold currently on the market
try talking to a gen set repair /retailer shop to get the make of carby being used on those motors
regardless of the engine make , what is required is the engine capacity (CC) so that the correct flow rate for the engine through the carby can be sorted to get the correct carby
once the carby is identified , it may be possible to get it from e-bay or a gen set manufacture spares that makes lpg or natural gas gensets
Install a pressure gauge at the gas inlet regualtor, conform it isn't less than specs normall 11-13" WC pressure. test this when it is surging, it sounds like fuel, or also incorrect governor gain setting
While propane and natural are similar, some devices require changes to properly operate on the selected fuel.
Information about this should be in the owners manual for the unit.
An off the cuff guess is that the gas pressure from the NG source isn't high enough, or that there is a gas regulatior on the generator that would need to be adjusted for NG.
Aquastar 1600H NG Natural Gas Tankless Water Heater Bosch AquaStar Model 1600H NG Natural Gas Whole house tankless gas water heater, 117,000 Btu input, natural draft with hydro-generated ignition. Provides endless hot water for one major application at a time . Can replace 40-gallon storage tank water heater. Optional Accessory: Model AQ1- Power vent with built-in... More freeze protection when venting horizontally. Capacity: 1 to 2 Bathrooms Dimensions: 8.75D x 18.25 W x 29.75H Weight: 40 Max GPM @ 45F Rise: 4.2 Energy Factor: NG .80 LP .84 Minimum Input: 28,000 Maximum Input: 117,000 Vent Size: 5 Gas Connection: 3/4 Water Connections: 1/2 Warranty: 12-year warranty on heat exchanger, 2-year on parts Features: Endless hot water Can save up to 50% off utility costs annually Perfect for one major application at a time No standing pilot, hydro generated
