All of a sudden, the oven does not heat up. The stove top and all the displays work fine, just the oven part does not heat up. Is there a fuse or breaker intenral to the unit or is it fried? THX
SOURCE: Maytag A9800 Top Loading Washer
Try rotating or switching all the controls to make sure one of them is not stuck in a "wrong" possition. Try starting the washer in the different cycles...if it works in some cyles but not others, the timer has probably failed.
SOURCE: Maytag stackable LSE7806ACE - dryer wont run...washer is fine..
I had the same problem, take the easy rout first and check for obstructions in your venting. Mine was clogged and it shut itself down (to protect itself?)
SOURCE: BURNER ON STOVE TOP NOT WORKING
some dirt or spilled food is in the orfus tbue or holes forcing it to come out under the burner!
If you ever replace the unit, get sealed burners the you can take them off and clean them!
GET HELP.
THESE GUYS CAN HELP!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
SOURCE: Admiral Electric Oven Control Panel Issue
that is a part number to the clock assy, assuming you have 110v to L1 on back of the clock and no display , that s a preyty safe bet youll need to replace that clock assy
SOURCE: Oven won't work
sounds like your bake element is gone
but the model number would help a great deal
pul out the stove unplug it, take off the back, and inspect the connections on the bottom element
if its gas its probably your ignitor
take out the racks
take out the bottom
set to bake
you should see a very bright light within a minute
if you dont thats the ignitor
anyway both parts are available
and both are a pretty starigt forward repair
