Samsung WA5451ANW top load 4.7 washer. Code "LO". After cycle lock mechanism clicks three times then throws LO code. I unplugged and got the same result several times. Manual says to call for maintenance. I can not find a manual online to show how to remove the top manually. I would like to open the washer and disable the lock, no children in house. Thank you.
SOURCE: long spin cycle of my Samsung WF8590NHM Front Load
Hi.
The error code is not 5D but SD, which means slow drain detected.
Check drain hose. Check drain filter attached to the pump. Check pump itself and pressure switch.
Regards.
Ginko
