My washing machine makes a very loud scraping noise when the drum is moving,even when i turn it by hand,could it be the brushes?.
That's exactly the sound mine is making - scrape, bang, scrape bang. I have a post where I pulled the front cover and turned on the machine. Below the tub where the motor sits, it looks almost like its missing some bolts but it isn't. The barrel moves back and forth as a normal function, but mine leans forward and the metal "housing" where the motor sits scrapes the bottom of the machine like some kind of suspension or springs are not holding it up. If I hold the tub back so it doesn't scrape it is fine, but I haven't found out which part is the problem. Did you have any luck?
Loud noise when washing, a scraping metal sound
More likely there is a bra wire caught between the inner drum and outer tub, possibly wrapping itself around the element in the bottom.
Possible that the INLET valve is also making noise due to faulty coil, check , confirm by disconnecting the valve.
It is so common that the washing machine can make
terrible noise in many ways and is a common fault. In all occasions it is
important that your observation is most important and so is vital to the
identification /rectification and solution. If you have noticed that machine is
vibrating when it is running then the motor /drum suspension has to be
inspected. Since these fittings are located on the underside of the machine it
is important that you look for the noise with a good inspection lamp. Manually
turn the motor and drum and listen for the noise, if so the motor bearings, the
drum agitator shaft and fittings must be checked. Also the suspensions which
include the shock absorbers and springs, the body clamps must be checked to be
in correct alignment and not changed in position. Tightening of the
mounting is also very important. Finally
in most cases a drop of OIL or smear of grease on the moving parts cane solve
most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For
replacement of bearings check for tips on this visual link:
http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
most issues.
Check this link :
For
replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
most issues.
Check this link :
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
most issues.
Check this link :
For
most issues.
Check this link :
bearings making scraping noise
washing machine is making scaping noise when washing and want turn but it still spins ok and drains
