Question about GE 28112 Trio Cordless Phone
Delete messages I swear I have looked through the instructions 3 times and nowhere do I see how to delete messages from the answering machine! How do you do it?
    Scholar:
  • 47 Answers
This is from the manual.
Erasing Messages
You may erase messages in the following three ways:
To erase a message while it is playing
1. Press and release PLAY/STOP button.
2. Press the review and skip buttons to select and play the message you want to erase.
3. Press the delete button, the current message is erased, and the next message plays.
To erase all previously played Messages in a mailbox
1. Make sure the phone is OFF (not in talk mode)
2. Press and hold the delete button until "ALL OLD MESSAGES ERASED" is announced.
To erase a message from the handset :
1. Press the flash/answerer button on the handset
2. Press the play/stop (key 2) on the handset.
3. Press the erase (key 0) on the handset to erase a message during playback.
NOTE: Erased messages cannot be restored.
Posted on Jan 09, 2009
Anonymous
SOURCE:
I have a Radio Shack digital answering machine 43-3808A. It is supposed to allow me to check message remotely but I cannot get it to work. I noticed another message at this website saying the same thing...
Looking at the manual
http://support.radioshack.com/support_phones/doc68/68590.pdf
The code is NOT changeable as near as I can tell. It is written on a label on your unit.
When it answers, after it plays the message, you should type in that 3 digit code. Suppose it is 123.
You should type in 123 and then immediately enter the command you want.
Try 9# to record a memo, and see if it records. That is, type 1239#, and you should be able to record a memo I think the two tones is a misprint. Most of the time you enter the code either while the outgoing message is playing, or immediately after the outgoing message finishes.
Mar 23, 2011 | Radio Shack 3808 Digital Answering Machine
How do you set the answering machine or voice mail on this phone?
First make sure the answering machine is on; press the On/Off button to turn it on and off. To set a message to be heard by those calling in: press and hold Skip/Annc. Begin speaking when A shows in the message window. Speak from about 9 inches away from the phone. Messages must be more than 3 seconds and less than 3 minutes long.
Press Prog/Mem and then Skip/Annc to hear the current message. Press and hold Setup until you hear the current setting (Selected announcement is A or Announce Only). Use Skip/Repeat to change the setting. No one will be able to leave a message if Announce Only is on.
After you have held the Setup button, as above, press Setup additional times to set the number of rings before the machine answers and the remote access code among other features.
To set the date and time, press and hold Clock for 1 second. Use the Skip button to advance the current digit; the Repeat button will subtract one from the current value. Press Clock again to advance to the next value to change (day of week, hour, minute, second).
Press Play to hear new messages; press and hold Play to hear all messages. Press Repeat to repeat the current message. Press Repeat twice to hear the last message. Hold Repeat to slow the message playback.
Delete a message by pressing Remove during playback; press Remove twice to delete all messages (if there are no new messages). A blinking F indicates the memory is full and messages must be deleted.
I hope this helps.
(btw additional instructions for the answering system are available at the AT&T website. Direct link: http://telephones.att.com/documents/product_Product/219/UserManual/1982/1855_manual_bkm.pdf which may or may not work.)
Oct 29, 2010 | AT&T 1855 Phone
How can I retrieve messages accidentally deleted?
Look for the manual of your AT&T 1725 digital answering machine
Jun 26, 2010 | AT&T 1725 Answering Machine
Code to retrieve messages
Here are the instructions you need to follow:
If you want to be able to play your messages from a remote location, you need to enter a two-digit Personal Identification Number (PIN) code (01-99).
To select a PIN, perform the following steps:
1) With the phone in standby, press [menu/clock] twice.
The system announces "Security code," and the current PIN code is announced as it is displayed on the base.
Then the system announces the instructions for setting the PIN code.
2) Press [volume/select/ ] or [volume/select/ ] until the desired number appears.
3) Press [set] to select the PIN code. You hear a confirmation tone, then the announcement "Security code" followed by the new PIN code is announced. After a few seconds, the system announces "To set ring time, press menu again."
Note: The PIN code is set to "80" at the factory.
Remote Operation
When you are away from home, you can operate your answering machine with any touch-tone telephone. Use this function to check for recorded messages, to play or delete messages, even record a new greeting message.
1) Call your telephone number.
2) During the greeting message, press [0] and enter your PIN code
3) The answering machine announces the current time and the number of messages stored in memory. Then you hear "To play incoming message, press zero two. For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command from the following chart:
Command Function Command Function
[0] then [1] Repeat a Message [0] then [6] Answering Machine On
[0] then [2] Play Incoming Messages [0] then [7] Memo Record/Stop*
[0] then [3] Skip a Message [0] then [8] Greeting Message Record/Stop*
[0] then [4] Delete a Message [0] then [9] Answering Machine Off
[0] then [5] Stop Operation [1] then [0] Voice Prompts
* For Memo Record and Greeting Message Record functions, the first time you enter the corresponding command, it
starts the Recording function. If you want to stop the recording, enter the command again.
Note: Once you enter the remote access menu, you must enter a command within 15 seconds, or the
answering machine automatically hangs up and returns to standby.
5) After all of the voice prompts have been played, you hear intermittent beeps indicating that the system is in the
command waiting mode. You may enter another command at this time from the chart.
6) When you are finished, hang up to exit the system. The answering machine automatically returns to standby.
Turn on the Answering Machine Remotely
If you have forgotten to turn on your answering machine, you can turn it on remotely from any touch-tone telephone.
2) Wait ten rings until the system answers. You hear intermittent beeps.
3) Press [0] and then enter your PIN code. The answering machine announces the number of messages stored in memory. You hear "To play incoming message, press zero two. For help, press one zero."
4) Press [0] then [6] to turn the answering machine On. You hear the outgoing message and a confirmation tone.
5) Hang up the phone; subsequent calls will be answered by the system.
Feb 28, 2010 | Uniden EXAI5680 Cordless Phone
We have a single Philips CD 445 Phone Our problem is how do we delete messages from the machine, we have lost the paper work with the instructions. alanbarlow1940@hotmail.com
Deleting an incoming message
From the base
Press (erase)f during message playback.
• The current message is deleted.
From the handset
During message playback, press OK
to enter the options menu.
Select DELETE. Press OK.
Deleting all old incoming messages
From the base
Press and hold (erase) during standby.
• All old messages are permanently deleted.
From the handset
Press (menu)
Select ANSWER MACHINE >
DELETE ALL. Press OK.
• The handset displays a confirmation
request.
Press OK to confirm.
deleted.
Note
Unread message(s) cannot be deleted,
and deleted message(s) cannot be
recovered.
Feb 13, 2010 | Philips Lands Phones
Lucent Technologies 1725 answering machine
Taken from the 1725's User Manual:
Deleting Messages
1 Connect with the answering
system.
2 To delete selected message
— Press
and release 3 while the message is
playing.
To delete all messages in a
mailbox
— After you have listened to
all messages and heard the two beeps,
press 3, and then the mailbox
number.
You can download a copy of the manual at the following URL:
http://telephones.att.com/telephones_ui/support/dsp_manual.cfm?manualID=164
Jul 15, 2008 | AT&T 1725 Answering Machine
At&t 1717 answering machine
http://telephones.att.com/docMgt/public/art/162/1717_manual.pdf
Deleting Messages
Delete All Messages
After you have listened to all messages and
heard the two beeps, press 3 ,3.
Delete Selected Messages
Press and release 3 while the message you
want to delete is playing.
Mar 23, 2008 | AT&T 1717 Digital Answering Machine
Howto change ring times for audiovox answer machine
how can I set the proper day and time on my answering machine same as above Audiovox AXT847
Nov 29, 2007 | GE 29878GE1 Digital Answering Machine
Motorola MD4260
I had the same problem.
Here is the solution that I received from Motorola tech support:
1.Delete all messages
2. Unplug the power and re-apply power
3. Quickly press and release << (previous message) and >> (next message) buttons together while the "Press review to receive setup instructions" message is playing.
The display will change from a segment scanning clockwise to anti-clockwise
4. Quickly press and release the On/Off button before the "Press review to receive setup instructions" ends. The display will change to a square scanning clockwise.
Note, this goes by quickly. I had to repeat steps 1-4 a couple of times before I got it right.
5. Press and release the delete button. The unit will emit a beep.
6. Press and release the on/off button. The unit will emit another beep and annouce "Press review to receive setup instructions"
Done!
Nov 22, 2007 | Motorola Mobility MD4260-2 Twin Cordless...
Deleting messages from AT&T 1738 digital answering machine
Press "3" during the message.
Press "3 twice" after all messages played and you here the two beeps.
Oct 18, 2007 | AT&T 1738 Digital Answering Machine
GE 28112 Trio Cordless Phone Logo
376 people viewed this question
Top GE Lands Phones Experts
martin hogg
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
