Question about Ricoh Aficio 1515MF All-In-One Laser Printer
Infotec IS 2215FPS procedure to reset admin password
I went into Service Mode, but we found SP 5, as they say. I just Copy sp 1, sp 2 Fax, Printer, Scanner sp sp 3 and 4. In Printer SP 3 I found nothing on the Network.
6ya staff
SOURCE:
Anonymous
  • 6 Answers
SOURCE: Service Mode
The service mode for an AP3800c printer only is different from the copier version. push down the up and down arrows together for a count of 7. Then push the enter key (#). The screen should now show "engine" in the window. If you are resetting a function you will need to arrow down to "service" then push enter (#) again. Use the escape key to exit from the sub menus. To exit back out of SP mode you will need to select "end" at the top line menu pressing enter to accept.
Posted on Nov 21, 2007
Derek
  • 68 Answers
SOURCE: How to enter ''service mode'' on Aficio SP C221SF Color MFP
this is priveledged information and kept away from non service personnel to protect both you and the device from unqualified access and possible damage.
if you have an issue that requires entering service mode please call for a ricoh tech this ensures that you are protecting the investment you have made in purchasing a ricoh device.
Posted on Sep 16, 2009
Anonymous
  • 58 Answers
SOURCE: My ricoh sp c811dn suddenly started displaying the
552...... A Heating roller warm-up error 2
?? The heating roller temperature does not reach the ready
temperature for 90 seconds after the heating lamp on.
?? The heating roller temperature does not reach 80°C for 13 seconds
after the IH inverter on.
?? Defective thermistor
?? Defective IH inverter
Related SC code: SC 542
1. Check if the heating roller thermistor.
This code is there to prtect against high temp in the fuser that could cause a fire...best to have a tech look at it
Posted on Feb 26, 2010
bouao198
SOURCE: SP C222SF multifunction Printer Problem
Dear colleagues,
I have aficio spc 232, when powering on, it stays displaying initialization message and never comes redy.
Please any one can help me to solve this problem.
Many thanks in advance
Boualem
UAE
Posted on Oct 05, 2010
micromatikal
Tim Grayson
  • 2777 Answers
SOURCE: I need the reset procedure
This is how you reset that error:
press the yellow "C" button
enter 107
press the red "C" button and keep it hold till the display changes
turn the power off with the big red switch on the unit
turn power on again
Thanks much - if somehow that doesnt work please reply.
Tim
Posted on Oct 25, 2010
How do I solve the sc 542 error problem on Ricoh aficio sp 3510dn printer when it does not have an online button or a number keypad?
You need to switch the power switch off.
Hold down either the online & escape or stop/start & escape while switching the machine on.
The machine should start up in service mode.
Select 1 for service mode
Select 5 for mode
Scroll to 810 SC reset and select enter
Select execute.
Switch machine off and on again.
Jun 22, 2016 | Ricoh Aficio SP 3510DN
Print SP & Scan SP are not avaible
check f the printer and scanner kit r installed!
Feb 02, 2014 | Ricoh Aficio 1027 All-In-One Laser Printer
How to make reset for sc 542 for richo aficio 410 printer
That code requires going into the SP (Service Protocol) mode. If you have the service manual, it will tell you which buttons to press to enter it and to exit service mode. Once you enter service mode, power down the printer. If that doesn't reset, you have to go back into service mode, go the the SC/Fuser reset SP and once executed, power down then restart. Hint: you have to go to "SERVICE" then 1 will display. Press the right arrow key until you reach "5" then press the OK button. You can then right or left arrow until you find the reset SP. Good Luck.
Oct 24, 2013 | Ricoh Aficio SP C410DN Laser Printer
How to restart Ricoh SP C231n?
hi there, try to do the following:
- make a program mode (SP 107)
if you dont know SP mode, press clear/resume button then 1, 0, 7 then clear/stop button for atleast 5seconds.
*the monitor should appear 1.system 2.copy 3.
then press 1, then press 7,8,0,7 then #
*the monitor should appear COUNTER RESET then press 1 to start, let it finished then turn off and on your machine.,
*the SC-542 should disappear
note: if this will not fixed the problem, there maybe a problem with your FUSING UNIT, check it!
Nov 29, 2012 | Ricoh Aficio SP C232DN Laser Printer
How to enter SP Mode for Ricoh Aficio sp 3200sf
"Menu" ? "#" ? "1" ? "9" ? "3" ? "4" ? "Menu"
The display shows "Tech Mode> Tech menu"
Press "OK" to enter Tech menu.
Jun 06, 2012 | Ricoh Aficio SP 3200SF Multifunction...
I need to replace hard drive for a ricoh copier 1045. How can I get the software for the hardrive, and what is the maximum size of the hard drive?
No need for software. The standard hard drive size is 10GB. I don't remember the exact limit but the machine will only recongnize a certain amount so it will do you any good to buy a larger capacity drive. Just get the smallest/cheapest one and you'll be fine. These take the smaller "laptop" size drive in case you did not know. Other than that just install the new drive and let the machine do the setup. If your old drive failed then keep in mind you will have lost any document server files, scan destination or fax destination info and will have to re-enter that info.
Good Luck
Feb 23, 2010 | Ricoh Office Equipment & Supplies
Error Aficio 550
reset the problem first if don't work then replace laser unit
1, press "clear mode" on up-right of panal.
2, enter 107
3,press and hold "clear/stop" for 3-5 second
4, turn power off and on
Dec 12, 2008 | Ricoh Aficio 450 Copier
Copier problume.
return SP1-902-1 to 0. Then, the SC will
be cleared.
Sep 23, 2008 | Ricoh Aficio 1085 Laser Printer
REX ROTARY DSM618 D SC545 ERROR CODE
you have to go into the sp modes to clear this code .pres the yellow c then 107 and hold down the orange c , do this all in sequence , it wil go in the sp modes and show copy sp .enter there and switch the power off wait 5 seconds switch back on
Jul 18, 2008 | Gestetner DSm515pfd Digital Copier -...
Aficio 1035
Not sure what SC818 is as not in my manuals please try the following.
Entering and Exiting SP mode
1. Press the Clear Mode key.
2. Use the keypad to enter “107”.
3. Hold down Clear/Stop for at least 3 seconds.
4. Enter the Service Mode.
To enter the Normal Service Mode:
Copy SP On the touch-panel, press Copy SP.
Once in the service mode turn the main switch off located on the left hand side of the machine wait 5-10 seconds then switch back on. This should get the machine working. Hope this helps
PLEASE DO NOT ADJUST ANYTHING ELSE WITHIN SERVICE MODE AS CAN DAMAGE MACHINE OPERATION)
Thanks J
Dec 24, 2007 | Ricoh Aficio 1035 Copier
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
418 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
gggg
Adorjani Laszlo
quennie732
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
