Panasonic PT-44LCX65 Television Logo
Paul Posted on Nov 21, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
TV will not turn on
Was watching my TV a few days ago. There was a loud pop, the screen went blank, and the TV powered down. I first thought it was the bulb, which has never been replaced, but now I am not so sure. Symptoms: when I power on the TV, the ON button flashes green. After a few seconds, there is a very fast metallic clicking sound for about 5 seconds, which repeats after another few seconds. The cycle repeats itself about 20 seconds later. The green light keeps blinking but I never get sound or picture. Any ideas? Bulb? Ballast?
Joseph Hoffmann
Level 3:
President:
  • Master 1,756 Answers
  • Posted on Nov 21, 2012
Joseph Hoffmann
Master
Level 3:
President:
Answers
1756
Questions
Helped
409009
Points
4988
Hi, It could well be the power supply that is in the back of your set. Have a repairman check it out. It's not a do it yourself thing. Good luck.
  • Anonymous Apr 17, 2013
    do you take all the screws out to get into the back of the tv
5 Related Answers
Anonymous
  • 790 Answers
  • Posted on Oct 02, 2007
SOURCE: Plasma TV
did you hear the sounds? or maybe you have defective power source in hot side..
djchillsnyc
charlie rodriguez
  • 152 Answers
  • Posted on Dec 14, 2008
SOURCE: The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Anonymous
  • 1077 Answers
  • Posted on Jul 05, 2009
SOURCE: TV clicked and went blank...no picture, no sound.
Most problems with TV not turning ON is a power supply related problem. The relay click are a normal process that powers up the circuit boards. Right now the TV is most likely in " Protection Mode ". The TV detected a bad circuit board and it will prevent the TV from fully turning ON. This keeps the other circuit board from being damaged. The power light blinking is a code.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet. This will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, blinking light codes, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Anonymous
  • Posted on Jul 11, 2009
SOURCE: my panasonic plasma TH-42700U it turned off while
solution of light blinking
Chi Chu
  • 8457 Answers
  • Posted on Mar 04, 2010
SOURCE: My Panasonic TH-42PZ700U 42in. TV doesn't turn on
Power supply board have dead capacitors.U know how to solders?Buy these capacitors to replaced them to have power back.Or u can buy a whole power supply board for the replacement at these websites Shopjimmy.com,Ebay.com for refurbish power suppply board.
1helpful
Samsung plasma screen went black. Was watching tv, heard a loud pop and the screen will no longer turn on. You can hear the tv turn on but no picture. Power is still working, just a blank screen.
Issue is either with the X or Y sustain board. Look for a cap that has blown or a cracked solid state device on the board. One of them is responsible for the ***** croak you heard.
How to diagnose my led tv issues
You most likely had a capacitor let go, they make a pop when the go out, inspect the PCB for a burned mark.
3helpful
It started 3 days ago the picture started getting darker and darker everyday then last night after turning the tv off which was off for several hours I turned it back on and a few min later there was a...
REPLACE THE LAMP IT IS LOCATED IN THE BACK OF THE TV THERE ARE INSTRUCTIONS IN THE OWNERS MANUAL FOR REPLACEMENT IT IS CONSIDERED CUSTOMER REPLACEABLE ITEM.
PART NUMBER 915B403001 Lamp (180W)
2answers
Vizio GV47L not turning on after a pop noise
screen went black due to power supply failure. check also inverter.
1helpful
2answers
check your power board, most likely that's the part that is causing the problem.
2helpful
Loud pop Blank screen 42 inch Viore Plasma
Unfortunately, that board is the inverter board. And for this model the inverter board is only supplied with the the PDP panel. The panel is quite expensive, here's a link if needed:
LG 42PX5D Replacement Part PDP Plasma Display Panel
Pioneer SD-582HD5 - screen went black, no sound, Poor remote feed
The blue tube might be leaking coolant in the high voltage area, that is the cause of the POP. This repair might not be a DIY because of the lethal high voltage surrounding the CRTs tubes.
The slow response from the remote could be because the coolant has affected the main board where the IR signal are going to the remote sensor.
Let me know if you require further assistance.
1helpful
Blank Screen
Hi Gemma - have a look at this forum - it may be similar to what you are experiencing. http://forum.eserviceinfo.com/viewtopic.php?t=5411&postdays=0&postorder=asc&start=0 Things don't look good for NEC owners I must say! Good luck Saty.
9helpful
3answers
TV turns on then off no picture
I was watching my tv and it just automatically turn off, everytime since then i turn it on it goes off in seconds without picture or sound comes.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
