I can not download apps to my tablet it keeps saying that i need to add another amazon address to my account but i already have a account and it is on there and when i try to add another address it brings up my amazon account and there is no where to add an account
SOURCE: I just got a Archos 7 Home Tablet and I am trying
Some android apps require a imei number with a phone number in order to work. Some of these apps include alternative texting apps, Google voice and others. Its not an android error, its just trying to save you from wasting time trying to get an app that will not work on your device.
SOURCE: my apps libaray on my
Sounds like you need to reset AppsLib.
This fix will wipe all your data, so be sure to back everything up.
Go to Settings.
In settings go to Go to "Privacy".
Select Factory Reset.
Select Reset Device.
Connect the unit to the computer using the USB cable and "Select" Erase
Everything"
The following will occur:
• The screen will display COBY
• The screen will display Android
• The unit will reboot to the Menu screen
Step 6- The unit will prompt to calibrate. Hold stylus on the center of the target.
Repeat as the target moves around on the screen. ****DO NOT *** press Return or Home".
The unit will display "calibrate success" and will return to the main /home menu automatically. If for any reason the unit went into standby mode and the touch screen does not respond, reset the unit using a pin.
After the Factory Data Reset, do not launch the Applibs yet until:
1- You have configured your Wi-Fi
2- Check/enable "Unknown Sources"- Go to Settings, Application Setting. Done.
You can now open appslib.
Open the Settings, then visit the Mail, Contacts, Calendars section and you should be able to remove any email address you have added to the iPad.
SOURCE: Just got my tablet and
Comment if you need more help and please rate a 4 if this was helpful
Thanks!
its need a credit card not email addresz
cannot change my email address so I will create a new account
