My owner's manual & box were lost in a an accident. I still have my Meade telescope, but can't see the model or serial numbers on it (it's on a tripod). I need a manual for it, but don't know which one I need. Can you help, please??!!
SOURCE: Meade, model: 6600, 6", need instruction manual & eye pieces
Sorry about Meade's responses, but their website has a download section for the telescope manuals - you may not find one that matches exactly, as they produce hundreds of models, but one that is close should suffice. As for eyepieces, there are several good vendors out there; Orion Telescopes, Meridian etc. Just check the barrel size; either .965" (Japanese standard) or 1.25" (American standard).
SOURCE: Meade Quartz Controller Model 784
You can send me an e-mail and I will try to help you as I have the very same Quartz Controller on my 20 year old 10" scope.
[email protected]
PS I am looking for a back up 784 controller for my scope.
SOURCE: meade LX200GPS telescope
The front panel for the telescope has an internal fuse. Remove the screws and look at the circuit board for a fuse. Replace with the same type and rating. The telescope has a diode with the fuse that gives some protection against reverse polarity, and the telescope should function on this fix.
SOURCE: I have a meade 4501 telescope. It has an
Hi there.
I have a meade 4501 telescope and it comes with a battery pack which contains 19 x 1.5v AA batteries. I also use my 12 volt adaptor which works fine and has never needed more power.Hope this helps.
Testimonial: "This was precisely what I needed. Thanks so much."
SOURCE: have this telescope model 60AZ-m
Look here:
http://www.meade.com/manuals/TelescopeManuals/Refractors/NG-NGC%20manual.pdf
or under the REFRACTOR header -- just go through the refractor manuals until you find one that is similar to your scope -- they are all assembled and used in a similar fashion.
