SOURCE: Cobra 19 DX IV out of frequency
I would definitely take it back for a re check. If the radio took a good bump perhaps it can cause it to drift off frequency. Turning the channel while holding his mic keyed does nothing but just throws a dead carrier. No value what soever. RF Gain is just to improve his reception by either lowering or raising the sensitivity of the receiver of the radio. Squelch is to silence the hissing sound you hear when no one is talking. Care must be taken to not to adjust too much or you wont hear anybody. It wont help his transmit audio at all. Recommend you get another Radio Check from someone else. He could be pulling your leg saying you don't sound good. Best regards and hope this helps some......................John.
SOURCE: my cobra dx 19 CB does it have to be grounded
YES you must have the power plug for ground at a minimum. The antenna must also be working properly. The out side of the CB case doesn't HAVE to be grounded but it is better over all if it is.
SOURCE: I have just bought a new Cobra CB DX IV (i think)
truckers also like it to have 300+ watts,, and don't tell them what you have and see the difference. lol
also the stock mic's are tinny sounding. trade it off for a good power mic like a cobra 75 $17.99 or any type of echo mic $35 i think.. those will make it sound like a big radio.., also check the SWR's !!!!! free at any cb shop to have them checked .. we don't charge unless it needs parts.
SOURCE: how to set up the cobra 19 DX IV CB Radio
first keep the manualhandy for the radio and antenna you are using. start by finding a good mounting point for the radio. install the bracket and cheeck the fit with the radio. next run the included power cord from the back of the radio to the fuse box. don't plug it into the radio yet. take the black wire and ground it to metal. try to find a screw goofyinto the metalof the car and loosen it, wrap the wire o. it and tighten it. next find thefuse for the stereo. pull it out and press I back inwith the red wire getting pushed into the fuse socket with the fuse. now you can plug in the radio. IMPORTANT! do not plug it in backwards. if you do you will blow out a diode in the radio and it will not turn on until repaired. turn the key on and then the radio. make sure it powers up BUT DO NOT KEY THE RADIO YET or you will damage it. the radio must never be keyed withough an antenna connected. mount the antenna as close to center of the car as possible le and according to theantennas instructions. run the coax to the radio and connect it tightly. now you need to tune the antenna for best SWR. there is a section in the radios manual and the antenna.manual that explains how to do this. rather then me type it all out you should have detailed I.structins already. if not let.me know and I will ppart it. after the swr is tuned for lowest you are ready to talk on the radio. enjoy.
I have found 2 links
for you to look at, amazon seems to be selling it for much cheaper than eBay. http://www.amazon.com/Cobra-19DXIV-Channel-Mobile-Compact/dp/B00083KUVS
http://www.ebay.ca/ctg/Cobra-Electronics-19-DX-IV-40-Channels-Base-CB-Radio-/54837100
