Samsung SMH8165STE Microwave Oven Logo
steven subiry Posted on Nov 23, 2012
Samsung microwave SE error - Samsung SMH8165STE Microwave Oven
1 Related Answer
Anonymous
  • 6771 Answers
  • Posted on Jun 14, 2012
SOURCE: Samsung microwave SMH8165W displaying error code -SE- and continuously beeps.
SE means system error, the keypad has a short in the membrane, or the control board has issues.
E-1 error on my microwave
Take your pick on the MAKE! Google search query on this is
make model error E1
Samsung microwave error codes
https://www.samsung.com > support > TSG01110365
A reference list of microwave error and information codes for Samsung microwaves. ... Close Menu. Open Search Layer; Cart Number of Products : 1; Sign In. Sign In / Create Account · Why ... Unplug the microwave or turn it off at the circuit breaker. If it's possible that ... E-04. Cooking Time Setting Over Error (Convection) ...
How to fix SE Error, 5E error, and E1 Error Fix - YouTube
https://www.youtube.com > watch
5:13 Understanding E1 error, 5E error or SE error. ... Your browser can't play this video. ... SE error ...
Oct. 30, 2018 · Uploaded by Technoo Lab
Can you please assist with Breville mode LMO530 Error E-1 ...
https://www.justanswer.com > ... > Appliance Repair
Nov. 20, 2020 - Yes, this is a system protection fault. The components attached to the main board are checked by the main board when a microwave is in use. 1 answer · Top answer: Thank you! Have a great weekend.
Oyster microwave error code E1 - Fixya
https://www.fixya.com > Forum > Microwave Ovens
Jan. 8, 2018 - No E1 error codes shown for this model of microwave! Have you checked your manual! Oct 7, 2014 GE JES636WK 700 Watts Microwave Oven. 1 ... Hotpoint JE740WY/GY Microwave Oven "Error code e1 ...
Nov. 23, 2019
E1 fault Samsung microwave CE1113f What to do
Aug. 17, 2018
How do I fix error EA1 code on my samsung microwave
Sep. 28, 2014
Oster Microwave E1 error
Mar. 6, 2018
More results from www.fixya.com
F2E1 - Error Code - Over-the-Range Microwave - Product ...
https://producthelp.whirlpool.com > ... > Starts with F2
Apr. 30, 2021 - There may be a problem with the User Interface / Keypad or the associated wiring. Power unit down by turning off the circuit breaker(s) for one (1) ...
1helpful
Samsung microwave -5E-ERROR
The " SE " error is reported by the microwave's software whenever one or more keys on the keypad are pressed or shorted for more than 60 seconds. An "SE" condition can result in the microwave oven running on its own, which can result (and has allegedly resulted) in house fires.
How to fix E5 code for Samsung Microwave
About 64,200 results (0.62 seconds) Search Results
    Fixing a broken Samsung Microwave - The dreaded 5E ...
    ? 4:30
    https://www.youtube.com/watch?v=_yWSU0kTkTg
    Mar 20, 2013 - Uploaded by Joe Devlin
    When my Samsung Microwave was just over a year old it failed giving me an "5E" or "SE" Error code which ...
    Samsung Microwave SE (5E) Error Fix - YouTube
    ? 9:23
    https://www.youtube.com/watch?v=YubSrHE7WFc
    Dec 7, 2012 - Uploaded by eric hatch
    I had pretty much decided to throw it away since the cost to fix it by a ... Fixing a broken Samsung Microwave ...
    Samsung Microwave SE Error FIX! - YouTube
    ? 1:33
    https://www.youtube.com/watch?v=oPQE2oLTR3o
    Jan 26, 2014 - Uploaded by jjthetechguy
    I am not responsible for any damage done to your microwave*** ***Do at ... Fixing a broken Samsung ...
What does this mean on my Samsung smh9151 microwave oven? -SE-
The SE error indicates a short was detected at the key pad. This could be a problem with the wiring (dirt at a connection) or a bad circuit board. If your microwave is under warranty, contact Samsung.
Since microwaves have high voltage, you may not want to try to fix this yourself. If you do, make sure to be careful. Some have fixed the error after unplugging the microwave. Then disassemble the microwave keypad area. Disconnect the various wires and clean all of the contacts. (Do one wire harness at a time so that you replace them in the right place.) Reassemble and plug in the microwave. Test if the SE error returns. If the error remains, then the control board needs to be replaced. To get the entire keypad and control board, seehttp://www.repairclinic.com/Shop-For-Parts/a6b160i468/Samsung-Microwave-Touchpad-And-Control-Panel-Parts . The board alone is here: http://www.repairclinic.com/Shop-For-Parts/a6b160i324/Samsung-Microwave-Control-Board-Parts .
I hope this helps.
SAMSUNG MICROWAVE SHOWS SE AND WILL NOT WORK.WHY?
SE is an error code for a shorted keypad, although the keypad might not really be shorted.
Unplug the oven for a few minutes to see if it clears the error code. If not, then leave it unplugged over night. If the problem persists, then you probably do have a shorted membrane switch on the keypad.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
2answers
Samsung microwave se error
see the video attached. God bless you
2answers
Samsung se error keeps coming back
i think your getting to much moisture in your microwave the exhaust fan is to small and can't handle it. once everything dries out you are able to rest it check with samsung.
1helpful
3answers
Top Samsung Microwave Ovens Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
