LG WM0642H Front Load Logo
Doris Hill Posted on Nov 24, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am trying to find the name of a part on my Admiral Washer Model #LNC6753A71
It is a lid part. White plastic and when you close the lid it fits down into the lid switch. It broke off and I am trying to find out where to go to replace it.
Richard Roth
Level 3:
Top Expert:
  • LG Master 9,472 Answers
  • Posted on Nov 24, 2012
Richard Roth
LG Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2628898
Points
28464
My admiral washer does not work on wash cycle. It will rinse and spin on any cycle but wash
hi Marilyn.
this is what i have found but not sure if this will help you out,if not go to the link at the bottom and see if it helps you out.
Step 1
Make sure the washer's cord is plugged in to a functioning outlet if the Admiral washer won't fill with water. Check your circuit breaker to make sure the power is on and reset it if necessary. Reset the dial and start the washer again. Turn both of the washer's faucets on to full power. Untangle any inlet hoses to remove clogs. If this doesn't work, your hose filter screens could be clogged. Disconnect the hoses from the washer and clean the screens of any residue.
Step 2
Close the washer's lid completely if the Admiral washer will not agitate. The washer will not start if the lid is open. Restart the washer by setting the control dial to the desired cycle. Momentary pauses during cycles can be expected. You may need to wait a minute or two to see if the washer starts. Check the circuit breaker to make sure the washer is getting power. Reset the circuit breaker if necessary.
Step 3
Check and reset the circuit breaker as above if the Admiral washer will not spin or drain. Untangle any of the washer's hoses to allow water into the machine. Check your drains for clogs that may be preventing water to move into the washing machine. Close the lid and restart the washer. The washer will not start if the lid is not completely closed. If there are excessive soap bubbles in the washer, the washer may have locked up because of this. Wash the load again without adding detergent.
Step 4
Rearrange the laundry so it is evenly distributed if the Admiral washer stops or if laundry is still wet at the end of a cycle. Untangle any laundry from the center post in the wash tub. Select the correct water level for the amount of laundry. Select a normal spin cycle for jeans, towels or other heavy loads. Close the lid and start the washer.
Step 5
Check the hoses to make sure they are tightly connected to the Admiral washer if it leaks water. If they are loose, tighten them with a screwdriver. Make sure the drain hose is secured to the drainage area. Avoid putting too much laundry in your machine or soaking laundry for over 30 minutes.
Step 6
Make sure the Admiral washer is on a level plane if it is excessively noisy. If it is not on even ground, move the washer so that it is level. Remember that some washer noise is normal. Thin floors can cause the washer to vibrate and move about and the noise level may rise and fall depending on the speed of the cycle.
admiral washer does not work on wash cycle Google Search
It won't turn on
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com Troubleshoot your Admiral Top Load Washer that has these following ... The machine will not complete cycle (fills but won'twash or agitate) I recalibrate it and it ... my washer will not startbecause of lid latch it is an admiral.
WONT DRAIN OR SPIN
Check lid switch and plastic tag on lid that operates the switch.
Switch can be shorted out to test operation, if machine spins, replace switch, do not leave shorted.
1helpful
ADMIRAL WASHER MODEL NUMBER LNC6753A71 HAS BURNING SMELL AND WON'T PUMP AGITATE OR SPIN BUT MOTOR IS RUNNING
its probably the drive belt that you smell burning under the basket,but there are numerous things that can cause it to burn,so you need to find where its froze up could be a clutch,the brake,the drain pump
The machine suddenly stop working right after finishing water had filled (the next action should start its washing cycle). Then there is no response, just as electricity is disconnected from it. Thank...
try opening the lid a couple of inches and close it down a few times,do you hear a clicking sound?if not the lid switch is bad.on the right side of the lid you should see a piece of plastic connected to the lid that fits into a hole in the top of the washer,this hits the lid switch,stick a pen or something in the hole and see if the washer works,send the model number and i'll tell you what switch you have on your washer,the model number is on the back wall of the opening where you put the clothes into the washer or to the left of the lid switch.if your lid opens strait up and backwards the number is directly under the lid when it's in the open position
The lid on my top loading admiral mega 22 plus washing machion is
These are plastic and will need to be replaced with new.
Once you have sourced new hinges then the machine top needs to be opened,
Electrically Isolate the machine, then at the joint between the machine front panel and top insert a flat blade 4" from each side to release the lid catches, tilt back the top to access the screws on the hinges and replace with new.
Opening cabinate? Admiral washer AAV 7000 AWW
Soak the lid around were the rubber bumpers stop the lid from letting it slam down, mine had become almost glued, I really had to pull hard to unstick them good luck. I have never seen a top lid with a lock.
2helpful
5answers
Washing machine stops at spin cycle and now won't run at all
Possibly the lid switch. It won't spin if it doesn't know the lid is closed. Some washers won't agitate with the lid open either, so let it fill until it starts agitating, then lift the lid. If the washer stops you know you've got a good lid switch. If it keeps going you know you need to test the lid switch. Just hearing if it clicks or not is not always a sign it's good. Some Maytag/ Admiral washer lid switches have more than one contact that must close to spin.
It could also be a problem with the timer. Put it in the spin cycle where you know it should be spinning. Make sure the lid is closed. Grab the timer knob and try wiggling the timer shaft up and down and around without turning the knob. If it starts and stops you've got a bad timer. You may still have a bad timer if nothing happens, but you'd have to check it with a meter.
Washing machine won't empty water
this can often happen on a top loader if the lid switch is not engaging properly.  The drum usually rotates (slowly at first, then much higher speed as the water is expelled) and, as a safety precaution, there is a locking mechanism for the lid. You will get the same result if you leave the lid open... cycle just pauses at the drain/rinse/spin part of the cycle.
Now, to solve the problem...
First we need to confirm the problem ...put the dial in spin cycle and see if you can open the lid, or if it is locked.  If the lid opens ,then you are probably not engaging the switch that enables the washer to lock the lid ( and turn on the pump).
THe switch is activated by a piece of plastic ( often in the form of a loop) attached to the lid which pokes through a slot in the metal top of the washer. a microswitch is located down in the slot. If part or all of the plastic piece is broken, the switch will not be activated.  If found to be broken, these are available at any appliance parats store, cheaply.
Sometimes the switch mechanism shifts down slightly or the internal workings of the switch wear down to where the plastic piece does not push the switch down far enough to activate.  You can test for this -*USING GREAT CARE*  by inserting a plastic stick or other non-conductive (electrical) material (a popsicle stick or plastic drinking straw works fine) that fits in the slot and can be pushed down an inch or so.  The test would be to put the machine in the spin part of the cycle and, with the lid open, insert the stick/straw down into  the  slot (you may hear a click from the  switch). This should turn on the pump if the problem  was that the switch had not been contacted properly by the plastic part on the lid.  Only do this for a moment as it is not safe to run the washer with the lid open (they lock the lid for a reason :).
If this procedure does start the pump, then you have isolated the problem and need to have the plastic part on the lid press down further into the slot to activate the  switch.   For a $50AU washer , i might try to build up  the plastic part with some tape to penetrate into the slot further (dont put on so much that it doesnt fit in the slot or gets in the way of the locking mechanism).
Alternatively you could replace the switch or plastic part, or both (replacing the switch will require taking off the front panel).
do the tests suggested and get back to me.
Gidday!
(from a yank that would like someday to visit coober pedy and ayers rock, along with the other spectacular places and people of Australia... oh, yes, and meet Crocidile Dundee too  :)
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
