The drain pump on my F&P IWL16 is leaking water. I've had the pump replaced 3 times, during which, the new control board with fuse bypass was installed to prevent the board from blowing again if the pump went out. Can you advise as to why the pump is leaking and does this mean I need yet another pump??
SOURCE: IWL16 leaves black specs on clothes
there could be something stuck in the machine between the two bowls. lifting the lid, removing the ring, agitator and inner bowl will easily check this. if the machine has become loud on spin, and the leak is actually from the bottom (more likely) then it could need seals and bearings replaced. don't run it too much more while leaking, electricity and water don't mix XD
