I need instructions for replacing the hvps
SOURCE: How do you replace the bell crank arm on a optra t612
I'm on my way to change a bellcrank on a t420, simple answer is, you need to cut the old one off.
Be carful not lose any springs though.
SOURCE: Lexmark T644 left side of prints faded
pull the toner cartridge out leave the bottom front cover open and bring down the top cover. with a flashlight check to make sure the charge roller is comming down straight if it comes down even. check to make sure the transfer roller has spring tension on the left side if the pring tension is present you will need to clean the flat leading edges of the mirror motor drive inside of the scanner located under the top cover.
SOURCE: Optra T612 fuser replacement
Here's an article in the Lexmark website on How to Replace the Maintenance Kit Parts on an Optra T Laser Printer. Just click on this link: http://bit.ly/95cW2R. Scroll down for the instructions on how to replace the fuser unit. Hope this helps.
