Kyocera FS-2000D Laser Printer Logo
Posted on Jan 09, 2009
New MacBook with Mac OS 10.5.6 doesn´t print with Kyocera FS-2000
I had an old iMAC and Printing with my Kycera was always without problems. No with my brand new MacBook I ran into drouble. The printer print only rubbish and the paper printed always is taken back into the printer before it will come out again. A Download of a new Treiber from Kyocery didn´t work..
What could be the reason?
Thank you all volker from cologne
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 07, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
217
Points
I stumbled upon your post having the same problem with a Kyrocera FS 1370d. Did you run the PDL Setup that is included in the installer from the Kyorocera Website. It installs the Kyocera Page Description Language that is reacquired for your Mac to communicate with the printer. It solved my problem!
Anonymous
Level 1:
  • Contributor 40 Answers
  • Posted on Jan 10, 2009
Anonymous
Contributor
Level 1:
Answers
40
Questions
0
Helped
38714
Points
91
The print driver ... look for the latest print driver. Also you may want to ask a technician to do a firmware update of your printer.
Kyocera prints garbage
driver issue. download latest driver and update printer firmware
3answers
Kyocera printer hookup to iMac using Ethernet connection
check the network printing settings in the printer, its a problem in the settings somewhere, unless theres a fault somewhere.
1helpful
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Mac OS10 print driver for Kyocera FS 3830N
Go to kyocera's website to download, ckick this link and it will take you to the driver you need.
OS 9
OS 10.2 and 10.3
OS 10.4 and 10.5
List of other drivers for this model printer.
Kyocera printing very slow
Has it always been slow, or is that a recent development? At its fastest, the FS-2000 only prints 31 pages per minute, and that's for regular single-sided 8.5" x 11" with no special requirements. Anything else will (thick paper, longer paper, duplexing, etc.) will slow the print speed down.
One thing you can try to speed up the print speed is to change your spool options in the print driver. Go into the print driver (Control Panel > Printers & Faxes, right click on the FS-2000 and select Properties) and find where the spool options are located. Try selecting different spool options (such as waiting to send the job until all the pages have spooled, or sending it page by page) to see if any of them affect printing speed.
There are other options in the print driver's properties which could affect printing speed as well. Look around the different tabs and try changing some of the options to see if they make any difference.
You can also go to Kyocera.com and download and install the newest version of the print driver, which might speed up processing as well.
Hope that helps!
2answers
Black dots printing on left side of paper
dots are usually always caused by the drum..drums are very easy to replace..(you don't even need a screwdriver)
here's how..
remove the unit that the toner sits into..it's called a process unit..comes out as a whole with the toners...
next open left cover..
remove waste toner bottle. (drum sits right above it!!!
next remove drum by pushing on grey button and pulling drum
out the left side of the printer.
as far as the jam message you might need to replace tray feed tires located up under the machine
Kyocera FS 920 won't talk to Mac OS 10.4
try this tutorial or this one and keep one thing in mind there is a generic print driver that mac can install this often works just as good as the one from the manufacturer
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Kyocera mita fs 1000+ error pages
install the generic postscript driver and go here to tune it http://localhost:631
Kyocera 3820n doesn't work right on my macbook OS X 10.5
if you have a mac os x operating system... you already have drivers built into your mac printer menu... try installing the generic print driver and see if that helps... sometimes it works better than the manufacturer's driver...
1helpful
2answers
Connect Kyocera Mita FS-1010 to Macbook (OS X 10.5)
in FS1010 printer usb port avilable u can connect the printer through usb port .
please delet ur printer driver and reconfigure it . use a usb cable to connect the printer it will work.one more u can put ur printer in network
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
