Where is the filter on the candy cwb714d
Machine will not spin, advised to check filter
    Sergeant:
  • 227 Answers
Lookng at washer there a little door on bottom left of the front of washer,open door an you see filter.you can goole your model number an you can see a video on how clean out your washer filter ok
Posted on Jul 06, 2019
2 Suggested Answers
6ya staff
SOURCE:
dazmaraz
Darren Moxam
  • 67 Answers
SOURCE: candy nova not spinning /
It sounds like a motor problem poss the brushes are worn alot of people asume, because the drum is noy going round that the washer is sticking. Or poss the drive belt as come off. Good luck
Posted on Mar 04, 2008
Candy washing machine grando gc42d error 3
machine is not draining or not draining quick enough and times out on drain check filter at the bottom rhs
Jan 25, 2015 | Candy Washing Machines
Washing machine does not work on any program though stop light and spin speed light are flashing t
The stop light and the spin light flashing are acting as an error code. Have you tried to google what this means? here is a link to candy error codes for that machine...
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3319-candy-grando-washing-machine-series-fault-codes.html
hope that helps
Jan 15, 2014 | Candy Washing Machines
Machine starts to spin out of control
Both problems could be related to a blocked drain, from what I can see in the manual. 3 Things to check -
1. Clean the filter - instructions can be found on age 24 of the manual.
2. Check the drain hose has no kinks/securely fitted.
3. Check the drain trap under the sink for blockages. Make sure waste water can drain away freely.
Keep a couple of old towels handy when checking the drain filter, if water is trapped in the machine, it will flow out of the filter housing when you remove it. Try a drain cycle for a minute or two before you remove the filter, then turn the machine off, and check it. That way you'll have drained as much water as it will allow.
The manual can be found here- http://service.candy-domestic.co.uk/manuals/pdfs/CNW156.pdf
Jan 07, 2014 | Candy CNW136 Front Load Washer/Dryer
Candy Grande o, stain vanish and 90 min light flashing
Try to find error codes on the Candy website.
Dec 20, 2013 | Washing Machines
My washing machine Candy CE10 does not spin and drain water
HI. firstly have you checked that all dirty water outlet pipe is clean and not blocked. or the cycle circuit could be broken.
Jan 13, 2012 | Candy Washing Machines
My madhine will wash and rinse but will not spin
The problem here is the drain filter. Access the machine and clear the drain filter. Then check the machine.
Any further questions please feel free to ask.
Nov 17, 2010 | Candy CN136 Front Load Washer
Candy CN146
0I have a candy intergraded washine machine ,could you tell me where the filter is please as the wash finish but still has water in, I put the cycle on to the water discharge and it emptys,then i put it onto a spin which works fine. But i need to know the problem
Nov 01, 2006 | Candy CN146 Front Load Washer
Washing Machines Logo
957 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
