SOURCE: LVM-37w1 after 5 minutes of viewing, picture and
I saw this fix posted on another blog by a fellow named Patrick. I tried it today and it it worked. It fixed my Westinghouse lvm-37w1. Basically disassemble the back of the TV (removing all the screws on the edges and middle). Remove screws holding bottom speaker and stand. There are 2 chrome rods extending down. There are small screws inside holding them on. You can turn the rods and unscrew the screws but need a small screw driver to put them back on. Remove the black cover on the back. remove the plates on the lower middle section. You will expose a printed circuit card. unplug wires and unscrew 4 screws holding it in. Remove it, turn it upside down and inspect the solder joints near the lower middle (especially under the gray relay on the other side). I found 4 solder joints that were cracked. Resolder the larger solder joints that are cracked or look bad (small solder joints are too delicate). Put it back to gether and it should work now. Mine works great. No more black screen with no sound.
