1) LUBE the deck belt, you must do it every 1 week after use. Otherwise you will the same problem that you have right now. This is by lack of maintenance. Maybe you have WORN deck belt.
2) LubE THE rollers bearing with WD-40 NOT use for deck belt. deck belt is with 100% silicone lube.
3) Test the input voltage motor, if there are the motor need repair. see my personal TIPS for troubleshooting motor.
4) Test the output voltage board, for input voltage board, if there are NOT the board is faulty.
See the block diagram
God bless you
