2000 Dodge Caravan Logo
mark anderson Posted on Nov 27, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to remove and replace the serpentine belt on a 2000 caravan
Thomas Perkins
Level 3:
  • Dodge Master 15,088 Answers
  • Posted on Nov 27, 2012
Thomas Perkins
Dodge Master
Level 3:
Answers
15088
Questions
0
Helped
3385747
Points
54869
raj somaiya
Level 3:
  • Dodge Master 5,370 Answers
raj somaiya
Dodge Master
Level 3:
Answers
5370
Questions
0
Helped
3569050
Points
14579
Check out the relatively help links, with diagrams to troubleshoot the problem: ---
For all types of---------
Timing belt routing diagrams for cars and trucks?
Click the link below:----
http://technoanswers.blogspot.in/2011/10/timing-belt-routing-diagrams-for-cars.html
For all types of
Drive belt routing diagrams for cars and trucks?
http://technoanswers.blogspot.in/2011/10/drive-belt-routing-diagrams-for-cars.html
These will help.
Thanks.
5 Related Answers
Anonymous
  • Posted on Jul 18, 2008
SOURCE: serpentine belt diagram:
The belt routing diagram is located on the top radiator cross member by the hood latch. You should see it when you open the hood. If it is not there, all Chrysler, Dodge, and Plymouth minivans, from 1993 to at least 1999, used the same 3.3L engine setup, so find someone with one and look for the diagram where I described.
Anonymous
  • Posted on Nov 20, 2008
SOURCE: how to replace serpentine belt?
how to remove and re-install serpentine belt?
Anonymous
  • 3 Answers
  • Posted on Nov 29, 2008
SOURCE: How to replace serpentine belt for 2000 Dodge Grand Caravan?
Mine fell off twice so far once when going through snow and other was going through rainstorm had to use jack wrench to pry down and slip on belt which was hard to do and don't advise you to try. Ok the pulley directly under the alternator and in the middle of 3 other pulleys is the one that is the tensioner. To do this right use a 15 millimeter or 5/8 socket or open end wrench, the longer the handle the better so you can get good leverage maybe you have a pipe to slide over handle. There is a diagram of the way the belt goes on under the hood. I have a 2000 Dodge Grand Caravan
Anonymous
  • 11896 Answers
  • Posted on Jan 17, 2009
SOURCE: need diagram for replacing serpentine belt on 2000 dodge caravan
I need to know which motor you have.
After you let me know, I will go to this website to find your answer:
http://www.autozone.com/N,316192/shopping/vehicleSelect4.htm
Anonymous
  • 6784 Answers
  • Posted on Aug 24, 2009
SOURCE: diagram for a serpentine belt replacement for 2000 avenger dodge
HI. i have posted the diagram requested below.
Testimonial: "This was exactly what we needed, Thank you so very much. "
How to replace the belt on 2000 dodge caravan
I had to replace the brushes on my 2000 Caravan alternator so I had to remove the serpentine belt. I was able to remove the belt by prying the idler pulley inwards to take of the pressure and slip it off so I think you should be able to do the same thing.
Replace serpentine belt on 2000 dodge grand
ON PASSENGER SIDE YOU NEED SAFELY RAISE SUPPORT VECHICLE ON JACK STANDS.PARK VECHICLE ON SOLID LEVEL GROUND.REMOVE WHEEL OR TIRE ON PASSENGER SIDE REMOVE SPLASH SHIELD, THEN PLACE A OPEN END WRENCH ON THE TENSIONER PULLEY LUG ROTATE TENSIONER TO RELIEVE THE BELT TENSION.
How do i take of a pulley and tensioner of a 94 Dodge Caravan 3.0 L V6
You'll need a Serpentine Belt Tool and a socket set.
Rotate the Caravan's serpentine belt tensioner assembly clockwise to relieve the tension on the belt. Slip the belt off the tensioner with your free hand before rotating the tensioner back to its home position. Remove the tool.
Extract the two mounting bolts that hold the serpentine belt tensioner assembly to the Caravan's front engine cover using your socket set. Depending on your physical size and dexterity, you may find this easier to accomplish through the top of the engine well or through the passenger-side wheel well.
Pull the old serpentine belt tensioner assembly out of the Caravan's engine bay by hand. Place the new serpentine belt tensioner assembly on the Caravan's front engine cover and bolt it in using your socket set.
Rotate the new serpentine belt tensioner assembly clockwise with the serpentine belt tool and then place the belt on the pulley by hand. Rotate the new serpentine belt tensioner assembly back into place. Remove the tool and close the hood.
1helpful
2answers
We need to replace the serpentine belt on our 1996 dodge caravan but the diagram has been removed.
Get the replacement belt, and then note the pulleys that have smooth finish, and note the pulleys that have the grooved finish.
Just 'thread' the serpentine belt, one pulley after another alternating between the smooth and grooved until the last remaining pulley is the tensioner pulley.
Use the breaker bar to allow the pulley to accept the belt, and you're done.
Need to replace serpentine belt on 2000 dodge caravan,,6 cyl,,air,,,, email [email protected]
OK, do you have a specific question? You'll need to jack up the front right tire and remove it. Pull the wheel well cover off to expose the belt. Use a vice-grip in the tensioner pulley (look for a 1.2 in square on the end of the pulley) to remove tension. Install as the sticker under the hood shows.
How do you replace a serpentine belt on a 2002 dodge grand caravan?
you need a 15mm wrench and skinny hands or a long belt router. place wrench on tensioner bolt and pull to rotate clockwise,at same time undo belt always holding tensioner, after removing belt from a couple pulleys release tensioner and finish removing belt from engine,for installacion reverse procedure.
1helpful
Serpintine belt replacement
OK, click on the link below to be directed to a full size photo of your belt routing diagram.
2000 Grand caravan Serpentine Belt Routing
Please rate and have a great day:)
2answers
Serpentine belt issues...
sometimes you can look at the back with flash light it is surounded by rubber if it is cracked or broken, But check your alternator and make sure you have pulled it out far enough it may just a imple fix.
4helpful
How to replace serpentine belt?
Serpentine belt
there should be a sticker somewhere under the hood or on the hood (inside) that tells you the proper routing of the belt.
If the a/c belt is seperate and installed on the outside of the pulley and the serpentine belt runs on the inside of the pulley.. yes you have to take it off first.
Robert
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
