Regardless of which cyle I wash/rinse with (warm/cold, warm/warm, or cold/cold) the water comes out fine during the wash cycle but barely trickles out (takes 30-45 minutes to fill) during the rinse cycle
It sounds like you have some buildup in the cold water valve screen. Where the hose connects to the washer there should be a screen inside the valve. Remove the cold water hose from the washer and clear any debri on the valve screen.
If this doesn't fix the slow cold water flow then you will have to replace the whole water valve assembly. The water valve is the piece that the hoses connect too and supply water to the washer.
If you have anymore questions about this please ask. I will be more than happy to help you out.
Thanks
Thanks so much for the advice. Worked like a charm!!
