If the unit agitates but when it gets to the spin cycle it just sits there you will need to replace the lid switch. Here is the part to order.
There is a video on that same parts page to show you how to replace it.
Keep me posted.
Unit does not agitate either and makes loud noise like a garbage disposal. Any other thoughts?
I see, you have a broken motor coupler. Here is the part to order and on the same page there is a video to show you how to replace the coupler.http://bit.ly/Vd0CSQ
Replaced coupler and dogs. Unit agitates now, but still won't spin. Back to lid switch?
Open the lid and press and release the lid switch. Does it click? Also, check to be sure the plunger is intact on the lid.
SOURCE: i have a kenmore ultra
please read the manual carefully, it contains all the infos & the solutions to problems you might confront. If not, please take it to specialst who can help
SOURCE: kenmore 80 series washer model # 110.92283100 that
You might have a sock in the pump.
It might also be a broken coupler or a combo of the 2. The motor is overheating and shutting down on overload.. Could be a coin or something in that pump.
How it works service manual and repair videos
Let me know what ya find out
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: Kenmore washer 90 series continue
Sounds like the fill switch needs to be replaced. A good way to test it is to set your machine on low fill and see if it fills past 3/4. If it does, it's the fill switch.
SOURCE: I have a Kenmore Elite
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
SOURCE: My Kenmore washer (22712) won't spin. It
The number one thing wrong when that type top load washer makes noise and does not spin, is a broken coulper between the motor and the gearcase. This tip i wrote will show how to replace the coupler...follow it to take apart the washer to see if the coupler is broken,if it is my tip will also be helpful to replace the coupler. http://www1.fixya.com/support/r10293994-whirlpool_made_washer_not_agatating
GENE
