Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
Posted on Jan 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My shark steam mop heats up but won't steam. help
Have a you ever filled your shark steam mop with water, plugged it in , allow it to heat up but then it doesn,t produce steam ? Well, it happened to me . What am i doing wrong?
  • 21 more comments
  • smartin7677 Feb 08, 2009
    My mop is all steamed out. Went through a tank of water working great. Refilled it to do another room and no steam. Emptied and tried again - no steam
  • joanopp Mar 15, 2009
    heats but won't steam. used less than 10 times. The 1-800 # sent me to India where I spent over 5 minutes telling them my name and address. They want me to send it to NC in the original box with ALL parts and a check for $9.95. I would pay the postage. Then I should see it again in 4-6 weeks. What really made me mad was they tried to sell me another. I told her "I've already got one" she says "Yes, now you'll have two" why would I want 2 when the one I have dosn't work? Small appliance repair shops are unable to get parts for this. I'm very unhappy. Grrrrrrrrr
    Joan in Colorado Springs
  • Anonymous Apr 21, 2009
    I've had my mop since Fall '07 and liked it a lot. Last week it stopped producing steam, even though the power was still on. I called and a man told me to refill it 2-3 times slowly and pump the mop, what kind of water was I using, was the pad wet or dry? The trick didn't work. When I called back today another man said I'd have to ship it in for repair, $17+ and $10 for shipping. Or I could have a new mop for $39.95 plus shipping. I told him I haven't even had this 2 years, why would I trust them to fix it or buy a new one? He had no other solutions for me. I paid $100 for a freakin mop, I'm not about to pay more for shipping/repair/replacement!
  • Anonymous May 07, 2009
    heats but won't steam. Used twice. Then I spent 1-800 # over 5 minutes telling them my name and address.They want me to send it to NC in the original box with ALL parts and acheck for $9.95. I would pay the postage. Then I should see it again in4-6 weeks. What really made me mad was they tried to sell me another. Itold her "I've already got one" she says "Yes, now you'll have two" whywould I want 2 when the one I have dosn't work?
  • katy_mcentir
    katy_mcentir Aug 12, 2012
    Mine quit steaming, so I added a cup of white distllled vinegar and plugged it in and it started steaming. So once a month I am gonna run a cup of vinegar through it. It is steaming like new now!! Soooo happy!!
  • Anonymous Dec 09, 2012
    you guys just saved my shark, thanks bunches.... y'all rock!!!
  • Anonymous Jan 02, 2013
    I took my Shark apart. I can clearly see that the hose has broken off and can fix that. I will clean out with a paperclip to get some deposits out while I have it apart. The thing that I don't know and need help with is, there is a long spring that came out of the unit and I see no signs of where it came from. Can someone please tell me what the purpose of this spring is as I see nothing apparent. I can be directly emails at [email protected]. thanks
  • Anonymous Jun 28, 2013
    Not only has mine stopped steaming, but now water is streaming from the cap on the reservoir. There seems to be a pinprick hole in the center of the cap and water is just shooting out of it. VERY disappointed. I've had it about two years, but have only used it half a dozen times. Reading on the forums, seems this is a standard issue with these things.
  • I used CLR to clear up any debris in it. The tip I saw was 1cup of ClLR for an hour connect and push out debris with steam however it did not work for me . I did however leave CLR in water container for 24hrs, plugged it up and left I for another hour. All of a sudden steam shot out and my shark vac now works. Just tried this yesterday! It works. Also when you leave CLR for 24 hrs put vac on porch or in vented area. ;-)
  • marilyn mayfield
    marilyn mayfield Nov 10, 2013
    Mine quit after 10-15 uses....lots of money, down the drain!
  • Jason Ashley
    Jason Ashley Nov 27, 2013
    unscrew the bottom, lift plastic cover, sqeeze little metal C-clamp and lift the white tube off the base. Inside the tube is a long spring, clean the stuff out of it with a needle, then slide the needle through the nozzle it was attatched too. reassemble..use. five minute fix!
  • Colleen Wieber
    Colleen Wieber Dec 28, 2013
    i tried this today and it worked. I did have to use the CLR twice but i'm happy with my clean floors!
  • Marta Molnar
    Marta Molnar Mar 17, 2014
    my brother stored my Shark steamer with water still in it. It would heat up but as you said it would not work, so I rinsed it out, twice then I put the little lever that makes it stay on with continious steam and just left it. all of a sudden it started to come through. The first sruff was gross, but I pointed into the sink then went about my business. I must also add that I did check each attatchment to make sure it was clear, run water through or look up to the light on the straight ones. Hope this helps figured all that steam would clean that out of the way time was all that was needed.
  • Anonymous Mar 18, 2014
    Will not heat up
  • Anonymous Mar 20, 2014
    how to unplug steamer so steams come out onto floor pad?
  • Anonymous Mar 23, 2014
    Shark MV2010WM2
    Water intake hose came off. Can't get my fingers in the hole to reattatch.
  • Anonymous Mar 24, 2014
    Plugged in but no steam?
  • Anonymous Mar 26, 2014
    not producing steam
  • Kyle Vantassell
    Kyle Vantassell Aug 27, 2014
    if any of your shark product dont work just go to bed bath and beyond and tell them you bought it there and they happily give you brand new one
  • Donna Roberts
    Donna Roberts Feb 13, 2017
    I had the same problem with my shark steam mop. After reading many comments here I put about a cup or so of vinegar in the water tank yesterday about 4 pm and let it sit overnight. I plugged it in at 11 am this morning, held it over my sink and turned it on the highest steam setting with the vinegar in it. It started to heat up and steam right away. Then there was a loud burst of steam and particles of sediment blew out into the sink and she started billowing out steam. Wonderful! I love this mop and will only use distilled water in it from now on.
  • Melissa Ronan
    Melissa Ronan Dec 23, 2018
    I did the vinegar trick, then got the huge explosion... but now I can't get the hose thing to stay clamped on. I REALLY need this thing to work again, my dogs are tracking mud everywhere and I HATE regular mopping. Any ideas to keep the clamp in place?
  • Regina Andrews
    Regina Andrews Jan 25, 2021
    My steam mop hums but there is no steam ... could the heater be bad .
    I did the vinegar tip over night sitting and still nothing....please help I love this mop
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 06, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
207353
Points
66
Problem: mineral dleposits. Just fixed mine.... DO THIS OUTDOORS. Add 1/2 c CLR to the tank, let sit for an hour, turn on, allow to heat and pump. May have to refill with CLR and repeat. Be persistent, and eventually you'll blow out a wad of dissovled minerals followed, happily, by billows of steam. Again, do this outdoors and keep the mop pointed away from people, plants and things. (I aimed mine into a cardboard box.) Follow up with a couple of tanks of water and pump until empty to clean out any residual CLR and loosened deposits. (I continued to get some black precipitate through the first water cleaning.) I will add that I began this process first with white vinegar, then with Lime Away..no luck put perhaps I was not sufficiently persistent. Or perhaps it was the sequence of attempts. (Also, do not take off the mop head...the part to which you attach the pads...it's tough to get off, does not allow access to parts that need cleaning (thought it would, not not so), and practically impossible to get back on.)
Alternatively, call Shark...they'll offer to repair for $18 plus $10+/- shipping, or may offer you a new one at "preferred customer" rate of $39.95 plus shipping. Good luck, and please remember to try the CLR outside.
  • 7 more comments
  • tjmcghee123 Mar 03, 2011
    I tried the vinegar and the lime away and no luck, now i took the head off to acess the bottom so it looks like it will be hard to re attach. I am trying the CLR method and will let you guys know it I can fix this thing. I inherited it from inlaws. So if it breaks no money loss for me and if it works, well I will be a first time steam mop user. There is steam barley coming out but not like the commercials show, does it really steam up?
  • Anonymous Nov 28, 2012
    I tried your suggestion. I noticed a pop and then steam did come pouring out but not from the floor piece. Steam was escaping from area were the floor piece and body connect. I don't know if this is a lost cause.
  • Anonymous Dec 31, 2012
    The pop was the noise of a hose getting disconnected from a tube.
  • Anonymous Feb 01, 2013
    Yes, we took it apart and that is just what happened. Not a very sturdy device for the price. Is working fine now. I use nothing but distilled water now. Thanks for the great suggestions.
  • jean corson
    jean corson Oct 29, 2013
    I used my shark steam mop 3 times I thought it was fantastic then then there was no steam wha so ever help !!!!!
  • Christine ODell
    Christine ODell Nov 29, 2013
    I tried the simplest thing...I stuck pipe cleaner up the steam hole a couple times while it's unplugged, turned it on and it worked!!
  • Joanne
    Joanne Jun 19, 2014
    The CLR worked for me. Thank you so much!
  • Kyle Vantassell
    anyone with any shark product if its broken at all just go to bed bath and beyond tell them you got there a you get brand new one no questions asked
  • Issy
    Issy Dec 10, 2018
    Hi just fixed my Shark steam cleaner. After letting it sit for 24 hours with regular vinegar in the tank that did not work SO used cleaning vinegar which has 10% acidic acid and again let sit for 24 hours turned (i heated the vinegar in the tank each time before letting it sit) and it blew out steam as good as anyone could want. Did not see any particals as I had it pointed into the drain of my laundry tub. This may help someone.
timdurniak
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Dec 31, 2012
timdurniak
Contributor
Level 1:
New Friend:
Answers
18
Questions
0
Helped
222883
Points
31
Here is a video that shows how I cleaned the heater core.
http://youtu.be/S4NglGXVv50
Anonymous
Level 1:
New Friend:
  • Posted on Nov 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
207353
Points
18
I had the same problem...after four uses, my SHark steam mop stopped producing steam.
I poked a pipe cleaner into the hole where the steam is supposed to come from because I figured there might be some build up in there. Then, I poured some white vinegar in the water resevoir and gave it a few shakes. After a few minutes, I plugged the mop back in. It took about 45 seconds, and after one pump on the handle, steam shot out of the base, and I was back in business. My kitchen smelled like vinegar, but at least my mop worked again.
I have heard that using distilled water can help avoid this problem.
Good luck, everyone.
  • Kim W. Oct 05, 2011
    I used the clean water from my fridge so not sure how it built up so fast but I tried the distilled white vinegar solution and it worked!!! Put some in my mop last night...let it sit over night...came home from work and I just turned it on and pumped it a few times and BAM!! steam!!!! Thanks !!
  • Anonymous Nov 18, 2011
    This actually didn't work for me, because it turned out that the hose from the water reservoir to the heating element had come off. The water sat inside the housing, so it acted like a clog, but I had to take it apart to see that the hose was off. Put it back on, worked like a charm. I have the 3501 and it was easy to take apart, with one exception: the stainless steel safety clamp around the neck of the case. That took me forever because I don't have a strap wrench, but in the end I used a nail to temporarily align the strap ends, and then a piece of twine knotted around it to hold it while I screwed it back in. Even then I had to use a pair of needle nose pliers to twist the knot on the twine and tighten it even further just to get the screw in the holes!
    But anyway, it was your vinegar suggestion that got me going, so thanks! I am a huge fan of vinegar for cleaning -- esp kitty smells -- so it's good to know I can use it in the shark too, not only to loosen tap water deposits but to turbocharge it on the carpet freshening. Thanks!
Anonymous
Level 1:
New Friend:
  • Posted on Jun 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
207353
Points
15
FILLED STEAMER WITH WHITE VINEGAR & SAT OVERNIGHT. EMPTIED IT & FILLED WITH WATER & PLUGGED IN. MACHINE GOT HOT BUT NO STEAM. UNPLUGGED MACHINE & STUCK A PIECE OF FLORAL ARRANGING WIRE UP INTO/INSIDE CHANNEL OF STEAM OPENING. SUDDENLY THERE WAS A WHOSH SOUND & BIG RELEASE OF STEAM SPRAYING OUT SMALL PARTICLES OF RESIDUE, THEN PLUGGED IN MACHINE & IT WORKED FINE. NOW ONCE PER MONTH, WILL INSERT FLORAL WIRE INTO STEAM OPENING ON BOTTOM OF MACHINE WHEN IT IS COLD/NOT PLUGGED IN, TO HELP KEEP LINE OPEN.
  • Anonymous Oct 06, 2010
    I have TWO broken shark mops. One at the spa I manage and one at home. Both crapped out after a year - ridiculous, and more ridiculous to have to pay to get it fixed. Anyway, I just tried this on the one at work with a wire and it worked like a charm! Great advice!
  • edymade Jan 10, 2011
    My Shark only worked one time before it crapped out. I poked a wire in the steam hole and also used the "back saver" button that bends the mop. That seemed to unclog the line and it started steaming again--not sure if the wire helped as much as bending the mop...
Anonymous
Level 1:
New Friend:
  • Posted on Feb 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
207353
Points
15
I shared the same problem of the shark not steaming. And I was able to fix it on my own with a some pilers, a small phillips screw driver & a safety pin (or tack). The most difficult part was putting the cover back on.
Being very frustrated when spending around a hundred that it lasted just shy of a year (didn't get around to it until after a year & the warranty void), I decided to open it up to determine & fix the failure. I first openned it up & plugged it in (CAREFUL - when working, it will get extremely HOT). This quickly told me that it heated up (dripping a couple drops of water on the metal heating unit will verify this), and it didn't steam due to a clog or leak.
After poking around & carefully pulling it apart, I found a build up clogging the path of the steam. I would imagine clogging others may be experiencing will be in the same location, and being a very simple design, it should be easy for me to explain where to locate it. I found the clog on the exit end of the heating unit, not in the hose, but in the port connected to the hose. Use the pliers to unclamp & take this hose off only at the heater end; this will be the hose inbetween the steamer & the where the steam comes out. Don't worry if a little bit of the spring in side of the hose breaks (it happened to me); it's only there to keep the hose from pinching. It was very obvious that the port on the heating unit had a build & was clogged by looking at it. It has a small openning, so a safety pin was all I had that would fit & all I needed to clean it out.
Hopefully to finish up, place the hose back on & then make sure to test it (aiming the steam in a safe direction) before completely it putting all back together. Again, CAREFUL when testing as parts & steam are extremely HOT. Best of luck & best of luck putting the dumb cover back on.
Anonymous
Level 1:
New Friend:
  • Posted on Mar 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
207353
Points
10
Same thing here....Am proud to say its working great now. First I swore at the thing a couple times, beat it against the floor, stuck a wire in the steam hole( while it was plugged in no less) Then I added vinegar, baking soda and food grade peroxide (found at health food stores works on many household things including teeth whitening. I was then patiently mopping for a few minutes and finally it started steaming again. I love this dammed thing!
  • allyoursluck Oct 25, 2010
    Best advice ever!!Put the wire in the hole, Crazy Whoosh came out and spit **** everywhere!!Then started steaming and working like brand new!!!THANK YOU SO MUCH!!!!
  • Anonymous Feb 04, 2013
    Put the wire in the hold and vinger in the water holder-Working like new!!
Anonymous
Level 1:
New Friend:
  • Posted on Jun 21, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
207353
Points
32
My problem was in the mop head itself where flexible tubing meets the plastic. I took out the 4 screws that connect the swivel mechanism, then the two that hold the flexible tube in place. Once that was free I could get a large straightened paper clip in the hole to break out the clog of mineral deposits.
  • bundace Sep 08, 2011
    My problem was where the tubing meets the motor. There was a hole that was made. I took off the hose from the motor, cut off the bad spot, and reconnected it to the motor... it works again, for now.
  • Carolyn Pendley
    Carolyn Pendley Aug 06, 2016
    So, I made the mistake of trying a drop of lavender essential oil.... steam was coming out of the main tank, but not making it through the connection into the "foot." Tried soaking in simple green. Finally took the swivel part of the foot apart and used a straight pin to clean each of the orifices. Score! Its all back together except for 4 screws... need to find a magnetic screwdriver.
Anonymous
Level 1:
New Friend:
  • Posted on Feb 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
207353
Points
12
My Shark Mop stopped working (steaming) after using it only 4 times. My solution...I filled tank with white vinegar and allowed it to soak in tank for an hour. I then took a wooden skewer (pointed end) and gently poked and turned it in the opening of mop head as far as it would go without taking the chance of breaking the skewer. Put pad on, started her up and VOILA...she steamed. I used the mop with the vinegar for a few minutes to, hopefully, clean out any mineral deposit residue and then rinsed tank out with distilled water. I will use only distilled or filtered water from now on. I always use filtered water in my iron and in my coffee machine because I know there can be problems with those appliances when using tap water. Guess the Shark needs the good stuff also! Margi
  • Linda Gayle
    Linda Gayle Nov 16, 2014
    Filled 1/3 Vinegar & 2/3 Water. Let it sit for 1/2 hour and also straightened out a paper clip and stuck up the steam hole. I have the purple vac and steam. After a few heavy push and pulls, a huge burst of steam came out and voila, she works.
Anonymous
Level 1:
New Friend:
  • Posted on Dec 28, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
207353
Points
11
I had the same problem. The only thing I had at home at the time was white vinegar. I filled the water tank with white vinegar. I placed the head of the mop on without the cloth pad. I pumped the mop several times. It steamed a little, but was not completely fixed. I let it sit overnight and then tried again in the morning. After several times of pumping the mop, it works just like it did when it was new!
Anonymous
Level 1:
  • Posted on Mar 28, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
207353
Points
6
Please be careful if you are trying this. We tried the vinegar and nothing happened so we tried the CLR. The shark steamer blew up on us inti bits with a loud explosion - very very frightening.
Anonymous
Level 1:
New Friend:
  • Posted on Dec 19, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
207353
Points
8
No solution - just a thank you for the posts here. Mop fixed!!! CLR was the answer. Used 50/50 solution, let sit for an hour. Plugged unit in and pumped and it sputtered and spit and cleared it out.
Before doing that I tried straight white vinegar - no joy. Then I tried the wire in the steam exit orifice - no joy. Took the cover off and the inner works are too snuggly fit to attempt taking apart - and I LOVE taking things apart. Put the cover back on.
Bought the CLR at Target.
Thanks again!! Bob 12/18/2010
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Nov 21, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
209578
Points
21
I had only used the shark steam mop twice and on the third time it would heat up but no steam. I put 1/2 cup of CLR in the steam mop and let sit for an hour. I also took off the cloth padding but left the plastic mop head on. I took it outside, set it on cardboard (to soak up moisture and cushion it) plugged it in and just started carefully pumping the mop and within a matter of minutes it was working like new. I made sure to rinse the reservoir out well afterwards and use water to steam out any CLR remaining in the tube leading to the mop head. Remember that the steam will be the CLR and to make sure all of it is out of the mop. This is a great solution from Libby OBX. Thanks.
  • Anonymous Oct 27, 2011
    HOw many times did you have to repeat this process? I've tried it twice so far... Am I a gonner? LOL
Anonymous
Level 1:
New Friend:
  • Posted on Sep 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
207353
Points
5
I have a Steamtek steam mop that stopped steaming...but there seemed to be steam coming out of the handle.The red light no longer turned green telling you the unit was ready to work.... Unplug unit before going any farther !!!so let the unit cool down...took off the back and discovered there is a small length of tubing connecting the actual steam chamber to a part just above steam chamber and this little tubing was cracked and ready to break off,seems to be quite flimsy...I am going to home depot or where ever I have to go to try to find a replacement piece of tubing...hope this helps
  • 2 more comments
  • Anonymous Sep 23, 2010
    Just back from getting new tubing,replaced the piece of tube that was cracked....all back together and now the steam mop steams up as it is supposed to....success!!!!!
  • lawler1 Nov 05, 2010
    Where did you purchase your tubing from, big box store, Home Depot or speciality agent? It appears to be a silicone based tube that can handle the steam temperatures.
  • Anonymous Mar 17, 2013
    I have the same problem with 2 of my sharks. Where did you find new hose? Did you get something stronger?
  • Anonymous Jul 02, 2013
    try auto patrs store. tubing made for engine compartment use will handle high temps
Lynn Janusz
Level 1:
New Friend:
  • Posted on Jun 24, 2012
Lynn Janusz
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
207353
Points
I have then Vac then Steam Mop and it was steaming but not coming out of the bottom. I took it apart and found the water tube blown out.. Luckily it was blown out at one of the ends so I could cut and reinstall. There is a spring in the tube that we had to cut a little because it was kinked but I think that was caused by the first time we took it apart. I'm going to call and see if I can just get the tube otherwise I will have to buy a new steam vac. I believe Hoover makes one that also dispenses a cleaning solution. I always sprayed down a bleach cleaner before steam mopping so the Hoover sounds like it may be a better buy.
  • Carrie Pike
    Carrie Pike Dec 01, 2013
    Watched a video on YouTube where a fellow replaced the tube with a black rubber tube bought at local hardware store or auto store and used the spring from the old tube inside the new tube.
Anonymous
Level 1:
New Friend:
  • Posted on Jun 02, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
207353
Points
Thank you, thank you to all of you that took the time to post solutions. I was all set to clean floors this morning with my Shark Steam Mop, and no steam!! My heart sank...it's my favorite floor cleaner! The tank was heating, but nothing was happening at the end that matters. I found all of these posts and decided to try the easiest one first...vinegar. I filled the reservoir with straight white vinegar, let it sit for about 10 minutes, plugged it in, pumped the handle a few times, and the machine started emitting that satisfying steam hiss. I then unplugged it, let is sit for a while, and then repeated the pumping and hissing. I don't know if I needed to do it so many times, but I wanted it to keep working. My kitchen smells of vinegar, but I don't care! My favorite mop is working again. Thanks!
Anonymous
Level 1:
New Friend:
  • Posted on May 27, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
207353
Points
I had the same problem - heat but no steam. Used the little fill cup to put 1/2 white vinegar and 1/2 distilled water in tank. Let soak for 2 hours. Plugged in and pumped like crazy and nothing happened. Unplugged and let it cool. Removed swivel head attachment, and used a straightened out paper clip to clean out the mineral deposits in swivel head and the main part of the steam mop. Plugged in again and warmed up and pumped like crazy. After 5 minutes or so, suddenly WHOOSH out came the steam! Kept pumping to clear out the mineral deposits and now it seems to be working perfectly.
Key things that I didn't know prior to this: USE DISTILLED WATER in the tank, EMPTY THE TANK after every use, and REMOVE THE SWIVEL HEAD immediately after every use. I also think I'll have to go back and use the vinegar and/or paper clip trick every couple months to keep it in working order.
Have patience, keep trying and you'll be able to fix it!
Anonymous
Level 1:
New Friend:
  • Posted on Mar 11, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
207353
Points
I had the same problem with my steamer not steaming, the tank would get hot but nothing...So, I took off the pad and looked at the bottom of my steamer. There is a very small hole there, so I stuck a toothpick in it and VOOM! all this steam just jetted out of it. My steamer was unplugged when I did this. I put the pad back on and filled with distilled water and it works just like it never broke. The only thing is have the steamer pointed away from your face when you insert the toothpick. You will hear it start steaming, so thats when you know to aim your steamer elsewhere.
Anonymous
Level 1:
New Friend:
  • Posted on Dec 22, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
207353
Points
Could coca cola work? If coca cola can dissolve a steak, do any of u think it could work?
Anonymous
Level 1:
New Friend:
  • Posted on Oct 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
207353
Points
Our steam mop had the heats-up-but-won't-steam problem. We tried the vinegar but it didn't work. So I inserted a wire into the steam hole (while it was unplugged of course) and moved it around for a couple of minutes. Then I plugged it in, and after about 30 seconds a huge plume of steam came out along with a bunch of dirty water. It's working great now and I'm SO glad I didn't pay EuroPro any extra money to fix it.
Jacqueline Zambrano Silva
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jul 03, 2013
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
207602
Points
My vac stopped steaming after 2 uses....sometimes mineral build up......in vented area I put cup of CLR in tank left it for 24 hours then dumped out liquid refilled it with water....plugged it in and after about 15 minutes steam jetted out. It works just tried it yesterday! Happy camper now thought I needed to buy another.
Anonymous
Level 1:
New Friend:
  • Posted on Sep 18, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
207353
Points
I took apart the unit 6 screws, not hard and found the heater tube was disconnected. Reconnected the tube with a spring inside to the end unit with niddle nose pilars, success!
  • Anonymous Jul 11, 2013
    I had the same issue, only mine actually split rather than just disconnect. I cut off the broken part of the hose with an xacto knife, reattached and now it is back to normal.
Anonymous
Level 1:
New Friend:
  • Posted on Mar 31, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
207353
Points
I just took taking a very small, long screwdriver and poked it up inside the hole the steam is supposed to come out. It seeded to break up anything that was blocking the steam, and I'm back in business. Good Luck
Anonymous
Level 1:
New Friend:
  • Posted on Jul 16, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
207353
Points
I was experiencing the same problems: heat, but no steam. I put a little CLR cleaning product and water in the tank and the problem was solved. Hope this helps.
  • mahamel Nov 14, 2010
    Vinegar was my solution too but I let it sit in the tank for five days while periodically plugging it in and pumping the steam button. Finally my patience was rewarded this morning with a crackling noise which I assume was spewing of the mineral build up and then steam, steam and more steam.
Curt Mueller
Level 2:
Passionate:
Visited the website for 10 consecutive days.
Habit-Forming:
  • Expert 182 Answers
  • Posted on Jan 26, 2021
Curt Mueller
Expert
Level 2:
Passionate:
Habit-Forming:
Answers
182
Questions
8
Helped
288562
Points
374
Have you worked it before and now it’s broken or is it your first time? Remember you have to pump the handle to let the steam out.
vicky garcia
Level 1:
New Friend:
  • Contributor 27 Answers
  • Posted on Dec 23, 2018
vicky garcia
Contributor
Level 1:
New Friend:
Answers
27
Questions
5
Helped
213192
Points
64
You need to clean the whole shark inside n out
Michelle Stanzel
Level 1:
New Friend:
  • Posted on Jun 25, 2016
Michelle Stanzel
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
207353
Points
12
Mine stopped steaming as well, after reading all of the answers on here I decided to try some CLR. I mixed it 50/50 with water, took the pad attachment off, plugged in the unit and pumped the unit into the sink. Cleared a lot of black deposits out of the unit (made a loud pop noise flooded by a steady flow of steam), then put each floor attachment pad on and repeated the process. I will say it would have been better to do outside (for ventilation purposes), however I opened a window and that sufficed. Was a super quick fix!
Pieter Vleeshouwers
Level 3:
  • Euro-Pro Master 2,029 Answers
  • Posted on Jun 19, 2016
Pieter Vleeshouwers
Euro-Pro Master
Level 3:
Answers
2029
Questions
0
Helped
4110439
Points
7389
Steam is a special thing with a special safety certification mark there are some rules and torsions inside by service manual to handle but one thing is very important to safe a lot of money if its a unit that not much should be used once a year then its good to learn howto clean the solenoid valve that controls the steam on or off there is the most case trouble that it hangs on lime aftera long time inactive since almost all steam cleaners suffer from inactive times
How To Repair an ASCO Solenoid Valve Affiliated Steam and Hot Water
here is not exactly the same but in principal the same thing to handle if the metal piece is
******* in the brass and very stuck make it on the brass part short time little hot with a burner it will loose inside is all the same the same principle a simply removable coil and inside the pipe
a little disk that closed and opened if its free of lime. there are more problems to have after a while but vinegar can prevent a lot and fill it with destilated water.
Dopple Ganger
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Posted on Jan 03, 2016
Dopple Ganger
Contributor
Level 1:
Habit-Forming:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
207353
Points
It is worth noting that "Bottled Water" and Distilled water are TOTALLY DIFFERENT!!
Bottled water is spring (or even tap, lol) water that has been bottled. Some mfgs. even add more minerals for flavor.
Distilled is just what it says, and is free of all component-clogging minerals.
Distilled is less than $1/gal, is found in the bottled water section (often on the bottom shelf) and will keep your steam mop working clog-free.
Mariah
Level 1:
New Friend:
  • Posted on Jan 05, 2015
Mariah
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
207353
Points
I read the same article about Coca-Cola it's worked on my dishes,laundry,garage,and change from the bottom of an old purse so far .I've tried it on other things it also removed the dirt between the grout in my bathroom without removing any grout.
Jade
Level 1:
New Friend:
  • Posted on Sep 25, 2014
Jade
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
207353
Points
I've tried the vinegar tip, and also tried taking it apart but no luck. Mine is the steam and spray model. I'd like to get a skewer / paper clip in to clear it but I cannot actually find the point where the steam comes out from (never noticed while it was working!) - it isn't obvious when I look at it. Could someone tell me where the outlet is that I should try and clear out? Thanks!
Anonymous
Level 1:
New Friend:
  • Posted on Jul 11, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
207758
Points
I think someone else mentioned this above, but my problem was not due to mineral deposits. Our Shark would heat properly, but when we pumped it would expel UNHEATED water. After removing the casing, I discovered that the hose leading from the heating element was split at the connection point, which was preventing hot air from mixing with the water. I cut off the broken part of the hose, reattached and now it works like a charm! If vinegar/CLR does not cure your problem, examine the hoses inside the machine NEXT. And do not remove the mop head either, you will waste a lot of time trying to get the darned thing back on properly!
William Morris
Level 1:
New Friend:
  • Posted on Feb 28, 2013
William Morris
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
207466
Points
I have a friend with 2 of these, she replaced one that was doing this exact thing, and now the newer one did the same...yes its mineral deposits, the newer one was a clogged tube from the heater unit to the outlet. the older one was the heater output was clogged. i used a very small stiff piece of steel wire to clean the tube. the older one i had to use a wire drill bit with a pair of vise grips to carefully open up the opening.. best way is to disassemble, if the unit is still hot wear leather gloves, carefully remove the heater unit till it is loose and can be moved aqround ( remove 2 screws from one side mount is easiest. slide the sping clip back, slide the heat covering back.. use an angled scribe to release the tube as it will be baked on by minerals, if it breaks off no problem there is still enough to reattach..clean the tube or nozzle ends.. scrub with clr to get all the deposits off the nipple end or you wont get the tube of spring clip back on... re assemble, fill the tank with CLR/ water mixture, plug in, find an old towel place on a tile floor or concrete, let the unit heat up and start pumping to flow the mixture to start cleaning the unit,,, run 3 tanks of this,, then 2 clan "distilled" or bottled water..use ONLY distilled or bottled water for now on!! run CLR thru once monthly and you will never have tyhis problem again!!!
Anonymous
Level 1:
New Friend:
  • Posted on Feb 01, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
207353
Points
I just bought mine and no steam! What is this any solutions or should I return it?
  • 1 more comment
  • Anonymous Feb 21, 2013
    I just bought mine. It gets hot but no steam.
  • Lisa Fernandez
    Lisa Fernandez Oct 06, 2015
    Take it back! Not worth the money...too many problems!
Steam will not come out, water is still heating shark steam mop-gray purple model, the problem occurs when it is plugged in (cannot use it, no steam) I have not tried anything yet
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
1helpful
2answers
Steamer not working at all. water tank / electrical outlet all check ok/plugged in and not doing anything
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Here also is a link to get any of the Shark Manuals that you need.
heatman101
2helpful
2answers
Shark Steam Mop - Gray/ Purple Vacuum: My shark steamer is heating up but not steaming. ...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
heatman101
I just filled and started using my steam mop. There was a lot of steam initially, but the mop quickly lost steam and heat within a few minutes of using it. Any ideas?
The water you are using is not able to make steam easily...
heatman101
Plug in but does not heat up, no light on but
The thing just plain broke...
heatman101
My shark steam mop will not heat up and produce steam. it has only been used 4 times. help
Empty the water and try different water...
heatman101
Hi I've plugged it in and all indications, green light on, heated water.. it wont steam,
heatman101
ssa
Shark steam mop will not release water or steam.
heatman101
aa
Euro-pro shark steam mop s3325
heatman101
zvc
Top Euro-Pro Vacuums Experts
ZJ Limited
ZJ Limited
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
