SOURCE: Maytag Top Loader Washing Machine Legacy Series
The drum should be on center. It sound like a damper pads issue. The damper pads are located beneath main support housing on base's machine. Check that they are on place and not broken. Good luck !
SOURCE: Maytag legacy series washer top load-squeaky during wash and rinse
very possible if squeaks in agitation top springs that hold tub needs greased under spring & plastic shield under spring. had same problem on big front loaders whirlpool
SOURCE: Maytag Legacy top load washer is SMOKING!
this is a bogus website that is trying to push smelly washer product....no real fixes and there are other products out there for less just use bleach first
SOURCE: Maytag Legacy washer MAV408DAWW loud noise, dumped all water
Tub bearings and seal have failed. My SAV405DAWW just started with the loud grinding and I am now in the process of finding out if I can fix it myself. Kurt
model no. sav205daww
