The clock battery is internal and cannot be removed or replaced except by a technician. It is recharged by your regular rechargeable battery, so there is no separate charging procedure. If you find that your clock and other permanent settings are being list when you remove your regular battery for charging, then it's an issue with the internal battery and should go to repair.
I am listing this tip for the Nikon Coolpix 995, but the tip is valid for all Nikon Coolpix models.
The Nikon cool pix settings are saved into an internal memory.
The internal memory is maintained by an internal rechargeable battery, that is recharged from the main Li-Ion battery. If you leave your Nikon overnight with no main battery, or if the Li-Ion batteries have drained, then the internal battery will also drain , resetting the clock and other settings, saved on the internal memory. The camera may even drain in about 6 hours depending on the camera, normally it takes at least 12 hrs to drain the clock battery. If the internal battery is resetting immediately, after you set the clock, or just after few minutes, then the clock battery must be replaced. The camera must be disassembled completely to replace the battery located on one of the two main internal boards.
Nikon says that the clock battery loosing charge is normal. I quote what they say on the publication titled " The Nikon Guide to digital photography with Coolpix" "…Backup battery of the clock The clock-calendar is powered by a separate rechargeable battery, which is charged as necessary when the main battery is installed. If the camera has been stored with the main battery removed for a long period of time, the clock may need to be reset. Once the main battery has been reinserted, the clock battery will recharge in several hours, during which time the main battery should be left in the camera."Original file: Download here If the clock does not work at all, and is resetting immediately, even though the Li-Ion batteries are fully charged, then the best thing to do is calling Nikon, at the number listed on the owners manual, telling them that you did not do any improper use of the camera, and trying to get the fault repaired as factory defect. That is not always possible, and the decision depends on Nikon customer service. See also: Nikon | Contacts Ginko.
Yes, there is a separate battery for the clock and all of your saved settings that is not user replaceable. All Nikon 1 cameras are still in warranty because the camera only recently became available. I would phone Nikon USA's Service Department at (800) 645-6687 Monday through Friday from 7:00 a.m. to 8:00 p.m. and they will tell you how to proceed.
First, turn the camera off and then remove and reinstall the battery. Turn the camera back on. If the clock and battery icons still appear, try resetting the clock. If this doesn't work, contact Nikon technical support at www.nikon.com and see what they have to say. It may require a repair but determine if the camera is still under warranty. If so, Nikon may repair it at no charge.
your "clock battery" is just a very little rechargeable battery, that will charge as soon as you put in a fully charged battery in your camera. You should wait for at last 12 hours, before you remove the battery. and the little battery can keep the clock running for several days.
Everything that is in the camera, only can be replaced by a skilled electronics engineer. The best thing you can do is contact a certified Canon repair centre and ask what it will cost to build in a new clock battery. But before you think it is a clock battery, make sure your battery is still in working order. Ask around if anyone you know has the same camera and borrow a charged battery for a few moments, to make sure it is not you camera battery.
Most of the cameras with a date time clock have a secondary internal power source like a small watch type battery some point and shoot cameras use a storage cell which takes power from the main battery. This means when the main battery looses power the camera clock will hold a setting for about 1 day or 24 hours. To keep the camera clock set you need to keep a charge in the main battery. Here is a screen shot from the manual explaining this function.
I probably need more details but, it sound like when you remove the battery to recharge it, the clock loses any power it had. Most people have a second battery. When the first battery begins to lose power, they insert the fully charged battery so the clock is only without power for a few seconds. Try that.
It may only happen enter date and time if you remove the battery in the camera., If your not removing the batteru out of the camera you should not recieved that message, unless battery is out of charge or no power.
You should use this battery Kodak Li-Ion rechargeable battery KLIC-8000. This is a special battery for Z812 camera,
Note: You must also need to purchase a charger for this type of battery. I guarantee you it will provide stable longer power for on your camera
This is a design glitch with these Nikons and many people are complaining about it. The clock battery is supposed to take a small charge from the main battery - enough to maintain the settings when the camera is not in use. However the clock battery that is used is not sufficiently strong enough to hold a charge for an adequate length of time.
As this is somewhat of a design flaw it is unlikely that a new clock battery will make any significant difference to the problem you are experiencing. Neither is it a user serviceable job and for these reasons I do not recommend that you try to replace the clock battery.
Nikon themselves say the following;
"The clock-calendar is powered by a separate rechargeable battery, which is charged as necessary when the main battery is installed. If the camera has been stored with the main battery removed for a long period of time, the clock may need to be reset.
This link will give you the user instruction manual for your camera;
http://www2.panasonic.com/webapp/wcs/stores/servlet/vProdSupportModel?displayTab=R&surfModel=DMC-FX8K&modelNo=DMC-FX8K&storeId=15001&catalogId=11017&itemId=94211&displayServiceCenter=false#
Page 19 describes the clock setting procedure - first check that you are doing everything as described, especially the "press menu button 2 times after finishing the setting"
If you still have no luck, then unfortunately there is a problem with the internal clock/settings battery/cell, which should normally charge from the main battery enough for 3 months - on this camera, the internal battery is not a user replaceable item, but your warranty should allow you to get it replaced free.
Sorry if bad news, hope it helps :)
