It started with just the red. When the tv was on it had the picture then red was on screen.Picture is off set. Then the blue and green messed up also. When I try to fix it in alignment it will not correct itself. The colors will not center in the square. In the picture you see all 3 colors and like the picture is doubled by each color.Please help with what I can do with this problem!!
Have you physically moved the set a great distance recently? Like , in a "move"
Jostling projection sets doesnt help gun alignment.
Get a qualified person to look at it
Your convergence amps are bad. Replacement is necessary and I would recommend contacting a servicer in your area. You can find an authorized JVC serivcer at this link http://maps.jvc.com/cAscList/
i have the same problem
hi i have a jvc 56 in projection built in may of 2003 and i have like red white and blue ghost lines on 3/4 of the left side any help you could give me in this matter thanks
kevin
[email protected]
