It just won't open there no noise.
SOURCE: zoom lens stuck inside with cap open
Having read a post from May 19th 2006 in which moderate shaking was suggested, I tried it and it worked. http://www.fixya.com/support/t103741-lens_cover_stuck Comment by David Cainer, posted on May 19, 2006 There must be something mystical about this website. No sooner had I logged the problem, when I picked up the camera and felt something click inside it. I shook it moderately vigorously and the lens cover opened.
SOURCE: fuji fine pix A400 zoom error
the camera may not be dropped but the lens may have initiated incrrectly, like it was turned on inside the case that the something prevented the lens to fully mount (telescope out) to default capture position.
it is repairable with Fuji Techs, but if the cost of the repair is worth 3/4 to the original price when you got the unit and is out of its warranty, then it will be best to get it replaced, and you may use this camera for harsh environments, like outdoor trekking or a helmet cam perhaps, it just a personal idea.
http://www.fujifilm.com/products/digital_cameras/a/finepix_a500/images/a500_e_manual.pdf
SOURCE: The lens on my Fuji Finepix s8000fd camera is
Your camera has a lens error, this
is such a common fault that I hope you don't mind me pasting my stock
generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common
reason that compact digital cameras get thrown away, but there's a fair
chance of recovering use of your camera again
The fault is
commonly caused by dirt or grit blocking the mechanism, or due to it
having suffered a recent fall. Another common cause is that the camera
was in a pocket or bag and the power button accidentally activated and
tried to open the lens against resistance. The mechanism may have simply
become
dislodged or there may be parts which have broken.
If your camera
is still under warranty and has definitely not been subject to misuse
then contact the Fuji service department in your country to find out about a free repair. If
the warranty has expired though a professional repair will far exceed
the
cost of replacing your camera. You will therefore have nothing to lose
by
trying to fix this yourself.
Please click here
and you will be taken to an excellent article provided by the Camera
Repair website. For the most part, you'll be guided on how to physically
manipulate your camera to try and clear the fault. Although the article
mentions Canon a few times, the advice applies equally to all cameras
with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good
luck, I hope you manage to use this information to fix your camera.
Please take a moment to rate the speedy and free answer I have provided for you and
any testimonial which you might wish to add is always welcome!
SOURCE: Have a fuji film finpix
Hello
Thank you for using FIXYA!!!
This
is a suggestion. If you do not feel comfortable trying it, you will need to take
the unit to your nearest service centre. Feel free to let me know if you
need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need
any further assistance. Also, please be so kind to let me know if you
found this helpful.
Regards
Andrea
SOURCE: fuji av 200
Send me an email to [email protected] and I will send you the manual. Put the subject as "Fujifilm finepix a200"
