Question about Tablets & eReaders
I canot send e mail from my Ipad, this just happened recently
I can still send e mail from my lap top. I have gone into "settings" on my Ipad and changed the port number as suggested on your site, but this did not solve the problem
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 37 Answers
Try deleting and recreating your email profile in settings.
Posted on Nov 29, 2012
Can't send emails on my ipad
see if this helps you out..
To resolve this you need to alter the port that your iPhone or iPad uses to send mailwhich can be done as follows. Go to Mail, Contacts, Calendars and select the account you wish to change. On the next screen, scroll down to the "Outgoing Mail Server" section and select the SMTP server that is listed.
Why can't I send mail from my iPhone or iPad? - Knowledgebase ...
customer.maginternet.co.uk/.../65/Why-cant-I-send-mail-from-my-iPhone-or-iPad.html https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=Can't+send+emails+on+my+ipad
Dec 23, 2016 | Tablets & eReaders
I am able to send emails via gmail, but not showing up in sent items and am unable to see my new emails unless I open up my g mail via safari
Your gmail wil not show if it's sent via gmail you will need to set up your gmail in you mail settings on your iPad that way you can send and read your mail using your iPad mail app you will find your mail in your settings hope this helps
Apr 09, 2015 | Apple iPad 2
How do I put the settings back to what they should be for sending emails and receiving them on iPad mini please
You should check the settings required by your mail supplier. Have a look in Google for your Mail Settings for the YYYY.ZZZZ after the @ in your mail address.
Follow their instructions EXACTLY or contact your mail supplier for these details.
Feb 20, 2015 | Apple iPad Mini
How can I resset my iCloud? I put a wrong email so now it won't verify my account
You can always restore it to brand new.
You need a computer with iTunes and the charghing usb cable.
Before restoring make sure that the Find my iPhone app is off, otherwise after restoring it will give you the very same wrong email.
Once that is off, connect the ipad to the computer and click restore.
Once restore is complete, at very end you will be prompt with 2 questions:
1. Set iPad as brand new
2. Restore from (your name) back up.
At this iem you can choose either one, because Find my iPhone is off. And now you can change the email address.
It is your best option since it is way too difficult without restoring it.
Jan 04, 2015 | Apple iPad (16 GB) WiFi Tablet PC
Old emails
Go to Settings>Mail, Contacts, Calendars. Under the Mail window - go to Show> and select the number of recent emails that you want the iPad to load in your email accounts.
While you are in the mail settings - tap on the email account, tap on the account in the next window, tap on Advanced in the next window and tap Delete - and select the amount of time that you want the emails to stay on the iPad.
In some mail accounts there will also be an option for Delete from Server - tap that and set it to never if you want to control when to delete your old emails.
Go back to your email inbox in the mail app and swipe down to the bottom of the window - there may be an option to "load more messages from the server" in blue letters. Tap that and you will download as many odl emails as you set up for in the Show recent messages setting. At the top of the inbox is a search field - type in keywords in that search field to find old emails.
You can also search for emails in the spotlight search. Go to the home screen and tap the home button and the search feature pops up. Type keywords in the search field at the top to find old emails there as well. When you tap on that email in the search, the mail app will open and you can read the email.
Jul 21, 2014 | Apple iPad (16 GB) WiFi Tablet PC
I have 1400 emails on my ipad I need to delete quickly.
In mail, when you are in a specific mailbox, on the top right side of the left hand column (in portrait view) next to "inbox" press "edit". Then in the bottom left corner there is a "mark all" option. You can do that and the unselect what you want to keep.
The other option, if you don't like those red numbers over the mail app is to follow these directions:
settings > notifications center > mail > select the desired mail account if you have more than one and then turn off "badge app icon"
this works for any app that has those (sometimes annoying) red icons. If you don't want that large number of unread emails on your mail app, use this method. If you want to delete them, use the previous suggestion.
Hope this helps!
iPad 3- iOS 7.1.2
iPhone 5S- iOS 7.1.2
iMac 21.5"- late 2013
May 30, 2014 | Tablets & eReaders
Ipad email problem
You have to go into settings and change both the incoming and outgoing server password. In many cases the Incoming POP3 server details are the first ones in settings, and then the Outgoing SMTP server details are on the Advanced tab. Sometimes you just check box 'Same details as the POP3 server'.
If that doesn't help too much, Click COMMENT under my post and I'll run you through it tomorrow using details from my iPhone.
Nov 11, 2017 | Apple iPad Tablets & eReaders
I can not open my attachments in Gmail
Check your gmail mail settings on the iPad. It seems you may have the wrong settings because typically your mail server settings would be set to "pop.gmail.com" when using Gmail on an iPad.
Hope that helps!
Mar 17, 2013 | Apple iPad 64 GB WiFi
My IPad requires an Yahoo signature - how can I obtain same?
Hello
. Tap on 'Settings'on the iPad home screen.
2. Then tap on 'Mail, Contacts, Calendars' on left column of settings screen.
3. Now tap 'Signature' option on the right column on 'Mail, Contacts, Calendars' screen.
4. Your current signature will appear (by default, it will show your name). Tap on it to make changes to email signature. You can add words like Regards, Cheers or add witty one liner quote to it. Only textual signature is supported (no HTML).
Feb 17, 2011 | Apple iPad (16 GB) WiFi Tablet PC
Tablets & eReaders Logo
127 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
