I want juki ddl-555 manual
Hi there
when you need to set timing please first make sure height of needle bar is ok. there's two mark at needle bar, the upper one is for height of needle bar: bring the needle bar at lowest position and in this case the upper mark must be equal with lower needle bar bushing.
second : set timing
move hand machine pulley at the same rotation and when the lower mark equal with lower needle bar pushing the tip of hook must be at the center of needle groove and just light touch not hit. that's all
best regards
ashraf abozid
CAIRO - EGYPT
SOURCE: juki ddl-227 industrial machine
Before all else. Turn off machine!
(1) break screws on the hook loose.
(2) tighten one back up very skightly, one you can reach when the needle bar is at its lowest position.
(3) lower needle bar to its lowest position.
(4) loosen the screw just tightened.
(5) position the tip of the hook behind the needle hole. the tip should be as close to the needle hole as possible without actually touching the needle
(6) tighten screws
(7) slowly hand turn the machine (depress the foot pedal to disengage clutch brake on motor) several revolutions to make sure the needle doesn't hit anything on the hook.
(8) if it passes this test, try on a scrap of fabric
SOURCE: i need instruction and parts manual for juki
JUKI HOME SEWING DIVISION
8500 NW 17 th Street
Miami, FL 33126
Phone: (305) 594-0059
SOURCE: Juki DDL-5530 Sewing Machine Manual
go to www.juki.com.jp login industrial sewing machine and you can doenload manual for juki machine
SOURCE: What needle type is used for the juki ddl 555?
Regular sewing machine needles. Choose the needle type and size according to the type fabric or thread being used.
http://www.euronotions.com/pdf/Schmetz_Sales_Guide.pdf
