Already replaced the 4 bad capacitors, but light still blinks green. I called electronic friend of mine that works on tvs. he said probably a bad dm board. Where can I find a replacement and one that doesn't cost more than a new tv? thank you, Lisa [email protected]
SOURCE: Blinking green light stays on and TV won't turn on.
Green Blinking Light - Order a DM Modual from Mitsubishi. Read the plug labels when reinstalling.
SOURCE: green blinking light problem too. on a Mitsubishi WS65869
You can go to this link they have the kits with the high temp higher volt capacitors and complete detailed instructions on how to do the repair.
http://servicemanuals.vstore.ca/
SOURCE: Mitsubishi WS-65513 blinking light
After taking the back off look to the left side of the tv at the bottom and you will se a silver metal box with some small holes in it. The DM board is in this metal box. Good luck
SOURCE: Mitsubishi WS-65513 "Blinking Green Light of Death"
I have mailed them to you. Please rate my answer! Thank you!
SOURCE: mitsubishi ws-65511 Green light blinking found bad
Front Keypads go bad alot on these sets,replace the Keypad.
