I got this rci-2980wx it wont power up its getin power the guy i got it from said it was but it wont power i think maybe a protetive diode but not sure and dont no where its located plz plz help
Maybe it's time for a reality check.
Maybe he doesn't think he's your boyfriend.
Maybe it's time to check out some other guys who might appreciate you more.
it could be several things......the rf final,bad mic,cold solder joint on the circuit board just to name a few.my suggestion is to find a good local cb shop,if no local shop find one along the interstate hwy most of the time they are located around or near some of the larger truck stops. tell the tech there what the problem is and go from there. good luck !!
Maybe the MP3 player thinks it has a fully charged battery, but it might have a damaged or deteriorated battery. If it turns on while charging, it's a battery problem.
You can test this with noid lights or a really good Digital voltmeter. Another method is to use a stethoscope place it on the injector and listen for it to click on and spray.
r u getin fuel-is the tank valve workin-maybe the float is stuck on carb-test to see if getin spark-ignition system could hav bad wire ie plug or coil connect
VR16 is not the low power adjustment, it's the CW Tone.
As far as I can tell, there is no low power adjust.
Try a different resistance pot for the RF Power.
