JVC LT-47X788 47 in. LCD HDTV Logo
Posted on Jan 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just bought JVC lt47x788 and did not receive owner's manual and do not know how to do the initail setup. When we turn on the tv it says no program or weak signal.
Jason Morris
Level 3:
  • Master 362 Answers
  • Posted on Jan 11, 2009
Jason Morris
Master
Level 3:
Answers
362
Questions
Helped
179465
Points
1276
Here is a link to download the manual. Let me know if this helps and please rate this solution.  lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jvc tv
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
2answers
HOW TO FIX JVC LT47X788 PIC FADES OUT
Try this
Ensure that a cartridge is not inserted
Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears.When the LEAPSTER menu screen appears, press the A button.Touch each of the crosshairs that appear with the stylus, Restart unit
I have a jvc television and bought a universal remote. i dont know the code for the remote. do you know the code?
These are the steps on how to program your Universal Remote Control to your JVC TV even without the list of code.
1. Manually turn ON your TV.
2. Press and "HOLD" CODE SEARCH
3. Press and release the TV button you want to set up
4. Release CODE SEARCH.
5. Press OFF/ON repeatedly until the TV turns off (you may have to press up to 100 times at a rate of once per second).
6. Once the TV turns off, press and release ENTER.
7. With the TV on, press any other button. If the TV responds, no further programming is required. If the TV does not respond, repeat steps 1-6.
2answers
Dish Satellite recently installed in my home supporting several tvs. MY JVC TV model LT32E478, designated as TV1, does not recognize any channels during program scanning. As a result, the timer on/off...
Hi mfaille
I`m going to help you with your setup but first;
Which connection are you using from the sat receiver to the tv?
Coax / standard rg6 cable?
Did you try to manually add(in the menu/tuner setup/find channel/add) the channel you need ?
Programming Onkyo Remote to operate JVC TV
Here are all the possible codes that will operate JVC TV's
JVC 0653 0053 0036 0154 0190 0371 0508 0606 0683 0192 0193 0218 0418 0093 1923
Can I still use my prologic receiver for my LCD TV ?
optical connection in tv is only input optical connection in receiver is only input will not work.need to connect rca jacks to tv's audio out jacks behind tv to any available input in receiver
JVC TU-DB1SK : Unable to setup basic freeview
1050 1071 1199 1259 1280 1315
Press and hold TV until the LCD blinks then try each code and in between press standby, when the TV turns off that will be the right code. May work for you, if not post back
kind regards
No manual
Make sure you have audio out from TV plugged into receiver. I have both Logitech 520 and JVC. It could also be in your setup of the remote.
1helpful
2answers
Some channels not programable
Bad tuner = verify part # from back of set to get part #...
Let me know..........................T.
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
