Question about Itochu C.itoh CI 5000 Matrix Printer
C.Itoh CI 5000 Matrix printer
Hi all, Got a bit of a problem with my matrix printer, seems that when printing anything over 5 pages on continuous paper it seems to "creep" down the page, therfore after 5 pages it finishes the last page on the start of a new one can anyone help? help would be much appriciated!! Thanks Dan
  • Danial Garratt Jun 11, 2007
    The paper im using is 11.5" should I still use 66lpp
Did you check the lines per page setting on the printer? For normal 11" length forms, the setting should be 66lpp.
Posted on Jun 08, 2007
6ya staff
SOURCE:
Skips pages while printing
check the page length set on printer/ system/print server in printer & fax
Jul 26, 2013 | Lexmark Forms Printer 2590 Dot Matrix -...
Need the XP driver for the citoh ci-5000. Was working well on old computer... it died, I connected it to another computer and I can't find the driver... please help, I need this asap THANKS Will
copy past this downbelow in your browser pick os
http://citizeneurope.com/drivers/dotmat.htm
Oct 06, 2009 | Itochu C.itoh CI 5000 Matrix Printer
Printer head damage the printer ribbon
See if there is a pin sticking out of the print head. If so, you must replace the head. You can google and find a head.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 04, 2009 | Itochu C.itoh CI 5000 Matrix Printer
How do you perform a self test printout on the Citoh 5000
Turn the printer on, press the ONLINE button to take it offline. Press and hold the RESET button and press the QUIET/SETUP button. This puts the machine in configuration mode. Now press the FWD LN FEED button once or twice, then press the ONLINE button. This will cause the printer to print the current settings
Jul 09, 2009 | Itochu C.itoh CI 5000 Matrix Printer
SOFTWARE FOR C.ITOH CI 5000 PRINTER
hi
you can download the driver for citoh ci 5000 printer here
for windows 2000 - http://www.updrivers.com/getdriver/Printer/Citoh/CI-5000-Windows_2000/17280.html
for windows nt - http://www.updrivers.com/getdriver/Printer/Citoh/CI-5000-Windows_NT4/17279.html
for windows 85 and 98 - http://www.updrivers.com/getdriver/Printer/Citoh/CI-5000-Windows_98_95/17281.html
or you can choose your own...
http://www.updrivers.com/drivers/Printer/Citoh/17/86/page2.html
thanks bye
May 19, 2009 | Itochu C.itoh CI 5000 Matrix Printer
CI 5000 is adding garbage characters to print jobs
You need to chage the print drivers to post script
May 29, 2008 | Itochu C.itoh CI 5000 Matrix Printer
Paper size problem
hi there, your problem is in page setup. make a custom size and it will print inside your paper sheet. ty
Dec 24, 2007 | Epson LX-300 Matrix Printer
Error code A21
A21 Home Error refers to the printhead not moving. Most cases, it is due to the fuse being blown on the main logic board. You have to remove the top cover. Open the clear cover, pop out the plastic pins, remove, then pull off the tractor knob on the right, remove the two screws at the top back of the printer, lift up the cover from the back towards the front. You will have to unplug an electrical connect ribbon from behind the control panel. Check the fuse and replace if necessary.
Aug 30, 2007 | Itochu C.itoh CI 5000 Matrix Printer
Page Setup
I am unfamiliar with this machine now - it has to be 10 years since I saw one. What sort of setup arrangemt for printing does the program allow- that is a word or spreadsheet in the file menu has a print set up panel - anything like that there. Failing that a an E-mail to Tech support Epson Also look up www.fixyourownprinter.com
May 16, 2007 | Epson LX-300 Matrix Printer
Home Error
Apr 02, 2007 | Itochu C.itoh CI 5000 Matrix Printer
Itochu C.itoh CI 5000 Matrix Printer Logo
453 people viewed this question
Top Itochu Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Marvin
Marvin
Are you an Itochu Office Equipment and Supply Expert? Answer questions, earn points and help others
