Every wash completes it cycle ok. When taking clothes out they smell like mildew, but this dont happen each wash. The drum smells fine. We descaled drum and checked filter all ok. HELP PLEASE.
this smell is caused by mold and mildew that has formed on the upper part of the outer drum -- the main cause of this is the suds in the wash tend to rise above the normal water line and never get rinsed away properly. so to get rid of the smell --- run a empty load of hot water ( hot/hot ) and when the cycle starts - add to the water 1/2 cup of white vineger and 1/2 cup of bleach, also add ( using a small container ) some more hot water to the machine to bring the water level up to a higher then normal height,,, let the machine complete the full wash cycle. now if the smell is still kinda there -- repeat the whole cleaning thing one more time,,, this should remove all traces of mold and mildew that has built up and you should notice a huge difference. to keep this from happening again,, try not to use so much detergent in the wash and after you wash your clothes - leave the lid wedged open slightly to let air into the unit so moisture can escape,, this will prevent mold from growing because the machine will dry out fully.
now at least once a month do this cleaning with the vinegar and bleach and you will never have this problem again.
the noise you're describing is normal - there is water in a sealed balance ring on the inner tub. To get rid of the mildew and smell, leave door open after cycle and use something like Affresh or "Smelly washer" stuff monthly or more often.
Step 1
Balance your washing machine. Standing water
breeds mildew and mold. A washing machine that isn't level to the
ground stands a higher chance of not draining completely. Take a level
and place it on the top of the machine along the front from side to
side and then again along the side from front to back. If the machine
is very off, you can adjust the feet to compensate or add something
under one of the feet if it is not flat against the ground. Portable
washing machines are especially prone to have standing water because
they are moved around and not leveled each time.
Step 2
Promptly remove your clothes at the end of a wash cycle. If you regularly leave the damp clothes in the washing machine
for an extended period at the end of the cycle, you will have mildew in
your clothes and your machine. The same is true if you put clean
clothes in the dryer and they are not completely dry when the cycle
ends and you don't go back for a few days to pull them out. Damp
clothes in an enclosed space for days will mildew.
Step 3
Leave your washing machine door open in between uses which gives the machine the opportunity to fully dry out.
Step 4
Use
white distilled vinegar in an empty machine. Run a load with only hot
water and two cups of vinegar to clean out the machine and freshen the
scent. Vinegar naturally eliminates odors and reduces the buildup of
soap residue in the washer which contributes to mildew development. You
can also add baking soda and/or bleach to the load for both their
sanitizing properties as well as assisting in ridding the smell of
mildew.
Step 5
Regularly
use vinegar when you wash your clothes. Add 1 cup of white distilled
vinegar to the last rinse cycle. Vinegar has acidic properties but it
is mild enough that it will not harm your fabric. It does dissolve
alkalines in laundry detergent which makes for cleaner and softer
clothes. The reduction of detergent buildup in your machine will help
to also reduce the incidence of mildew.
Step 6
If
you have a front load washer, they are particularly prone to mildew and
mold. Follow the manufacturers suggestion as to how much and what type
of detergent should be used. It is generally less than the traditional
top load washing machines. Once again, additional soap residue helps to
breed mold and mildew. Also, pull the seals back from around the door
and make sure there isn't a build up underneath them that needs to be
cleaned out.
Step 7
Finally,
if you have done all of the above and nothing seems to work there are
commercial products available that are recommended.
Run a wash cycle (no clothes), with a cup of baking soda, regular detergent and hot water. Leave the door open after each wash day to dry the interior which helps prevent mildew returning.
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
pull out soap dispenser draw and look up to where water comes out. my mach was full of mildew. i removed the top of dispenser soaked in bleach. i believe this is where mildew problem starts and spreads to drum and gasket
yes it could . If you are trying to pump the water 7 feet or more above the floor then it will at the end of the cycle get air into the drain hose causing cavatation, the result when the machines stops is the water running back down the drain hose back into the tub and that is what causes the musty smell.
Lower the drain if possible
washers and dryers dont make smells themselves its a problem with something u might be putting in it. if u tend to add alot more detergent then usual to your towels then they never completely rinse the water out and will have a mildew smell
A 65mins wash cycle taking 2hrs to complete
