I've lost the remote to my Sansui TV. How do I reset or disable the parental control without it? I called Sansui customer service and was told the only way to resolve is to buy another one of th
    Top Expert:
  • 14,553 Answers
The remote is cheap by modern standards and the ONLY way.
Posted on Dec 03, 2012
6ya staff
SOURCE:
Anonymous
SOURCE: Forgot V chip password on Insignia IS-TVDVD20A
i have an insignia hdtv and the manual says if you forgot the password, enter in 3448 in the password box to reset, it might be the same for yours, good luck
Posted on Jan 11, 2009
Bob Citizen
  • 520 Answers
SOURCE: Sansui COM3101A 13" Tv/VCR Combo Problem
You can try the codes for Orion, Emerson, and RCA. Call the number on the back of the set to see if the original remote is available.
Posted on Oct 23, 2008
jason michael
  • 106 Answers
SOURCE: want to program Dish remote to run sansui tv
  • what kinda off provider!! there is a web sight go under universal remotes and look up the remote you have there should be a code for your remote this should help!!!
Posted on Mar 26, 2009
Bob Citizen
  • 520 Answers
SOURCE: HOW TO REMOVE PANEL LOCK ON A SANSUI LCD TV WITHOUT REMOTE
That tv usually has the customer service number printed on a sticker somewhere on the tv. Give them a call. They will help you for free. I hope this helps you.
Posted on Apr 24, 2009
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Hi, The parental control is on
You cannot unlock the unit without an original remote.
Posted on Nov 08, 2009
Need to know how to remove the red key on tv and code
When a red key appears in the lower left corner of your Apex television screen, the set's V-chip is engaged, preventing you from watching restricted content. You can override parental controls and reset your television's pass code with your remote.
Parental Lock
  1. The Apex prompts you to enter a 4-digit code when you set up parental controls. You can block programs according to their MPAA ratings or their content designations, such as V for violence or S for ****** situations.
Disabling the Lock
  1. You can override parental controls on most Apex models by simultaneously pressing the F and mute buttons on the remote control. If you own Apex models GT2011J or GT2011S, hold the remote's display button for ten seconds. The red key will vanish and the V-chip will unblock your program.
Override Codes Apex's default parental lock control code is 6688, so if you haven't set a new code, entering 6688 will remove the red key and unblock your program. If you've set a new password and forgotten it, entering 3308 will reset the code and unblock your program.
Sep 25, 2012 | Apex Digital Televison & Video
Parental controls
try giving the reset ...........
Jun 29, 2008 | Sansui DTV2760 27" TV
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
Hisense H32V77C password reset
I couldn't find it anywhere in the service manual but you can try calling there support line. default is 0000 if that helps anyPhone: 1-678-318-9074
Fax: 1-678-318-9079
Jul 05, 2012 | Televison & Video
Have Sansui @0" tv/dvd/vcr combo that my son locked the parentals control
this problem need a technical assistance from any professional to service your unit to reset and by pass the codes..
Mar 20, 2008 | Sansui DTV2760 27" TV
I bought an insignia tv at my local Future Shop as an out of box item. My problem is that is didn't have a hand held remote and there is a parental lock in place that will not allow me to watch 14+...
Acessing personal secrect codes is not possible,could be anythings,tries call Insignia tv customer service 1-800... telephone line in ur manual ask them how to reset personal screct codes.Must have the original tv remote to do this,like entering numbers.Try website like Remotes.com to buy an exact remote to ur original tv remote.
Nov 15, 2010 | Insignia Televison & Video
Apr 24, 2009 | Sansui H TV2600 TV
Need to disable V chip for Sansui TVS 2746 27"Tv
Call the customer service number on the set.
Oct 22, 2008 | Sansui DTV2760 27" TV
Override Parental Control
Customer service at RCA stated that you have to simultaneously push the menu button on the TV and the volume down button on the factory issued remote hold for three seconds and the parental should unlock and allow access again.
Jun 29, 2007 | RCA F32645 32" TV
Televison & Video Logo
344 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
